跳转到主内容
Sony Cyber-shot DSC-HX1 LCD Screen Replacement
你所需要的
  1. Sony Cyber-shot DSC-HX1 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,1
    • Extend the LCD screen away from the camera to access the screws on the back of its housing.
  2. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Unscrew the three #00 2.0 mm Phillips screws on the back of the casing.
  3. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Place the camera with the lens down.
    • Tilt the screen upwards to see the screw on the bottom of the housing.
    • Unscrew this #00 4.0 mm Phillips screw.
  4. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: 步骤 4 中的图像 1,1
    • Pry the casing apart using your plastic opening tool. Begin by prying at the hole where you removed the screw and continue along the seam.
  5. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: 步骤 5 中的图像 1,2 Sony Cyber-shot DSC-HX1 LCD Screen Replacement: 步骤 5 中的图像 2,2
    • Lift the transparent section of the plastic housing off.
    • Lift the rubber screen bumper off of the screen.
  6. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: 步骤 6 中的图像 1,1
    • Pull up on the screen to reveal the data attachment cable.
    • Carefully pull the LCD screen away from enclosure to remove the cable and screen completely.
结论
6等其他人完成本指南。
Brianna Greenlaw
于04/06/15注册
1,289 声望
创作了5篇指南
团队
Cal Poly, Team 17-3, Forte Spring 2015 Cal Poly, Team 17-3, Forte Spring 2015 的会员
CPSU-FORTE-S15S17G3
4 名成员
创作了10篇指南
5指南评论
What is the lcd screen part number? And where can i find it online? I need to replace my dads cracked screen.
sportyvangchick - 回复
lao90227ay
s300gc05lb9e21xmo usp5280371
lajos rohony - 回复
Screen LCDOnline booking
prince Choudhary - 回复
qual tela de lcd posso usar?
não achei
Thayane Laurencio - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 20
过去 30 天: 56
总计 3,920
