跳转到主内容
Sony Cyber-shot DSC-H300 Screen Replacement
你所需要的
  1. Sony Cyber-shot DSC-H300 Screen Replacement, Removing screws: 步骤 1 中的图像 1,2 Sony Cyber-shot DSC-H300 Screen Replacement, Removing screws: 步骤 1 中的图像 2,2
    • Remove the four 6mm Phillips #00 screws.
  2. Sony Cyber-shot DSC-H300 Screen Replacement, Removing screws: 步骤 2 中的图像 1,2 Sony Cyber-shot DSC-H300 Screen Replacement, Removing screws: 步骤 2 中的图像 2,2
    • Remove the two 6mm Phillips #00 screws.
    • Remove the two 3mm Phillips #00 screws.
  3. Sony Cyber-shot DSC-H300 Screen Replacement: 步骤 3 中的图像 1,3 Sony Cyber-shot DSC-H300 Screen Replacement: 步骤 3 中的图像 2,3 Sony Cyber-shot DSC-H300 Screen Replacement: 步骤 3 中的图像 3,3
    • Use the flat end of a plastic spudger to pry apart the rear cover from the body of the camera.
    • Be careful not to damage the three plastic clips securing the top edge of the rear cover.
  4. Sony Cyber-shot DSC-H300 Screen Replacement, Screen: 步骤 4 中的图像 1,1
    • Remove the two 6 mm Phillips #00 screws securing the left side of the metal frame.
    • Gently pull the metal frame away from the screen.
    • Lift the screen with the spudger and flip it to the right.
  5. Sony Cyber-shot DSC-H300 Screen Replacement: 步骤 5 中的图像 1,1
    • Remove the four 6mm Phillips #00 black screws.
    • Lift the metal plate away from the board.
  6. Sony Cyber-shot DSC-H300 Screen Replacement: 步骤 6 中的图像 1,1
    • Disconnect the LCD cable.
结论
3等其他人完成本指南。
Zachary Meyer
于02/14/18注册
455 声望
创作了3篇指南
团队
USF Tampa, Team S1-G6, Nance Spring 2018 USF Tampa, Team S1-G6, Nance Spring 2018 的会员
USFT-NANCE-S18S1G6
3 名成员
创作了10篇指南
一条评论
where can i find the rear screen for sony dsc-h300
Michael Ramos - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 13
过去 30 天: 54
总计 1,825
