跳转到主内容
Sony Cyber-shot DSC-H200 SD Door Replacement
你所需要的
  1. Sony Cyber-shot DSC-H200 SD Door Replacement, SD Door: 步骤 1 中的图像 1,2 Sony Cyber-shot DSC-H200 SD Door Replacement, SD Door: 步骤 1 中的图像 2,2
    • Using a screwdriver, remove four 6mm screws located on the back panel.
  2. Sony Cyber-shot DSC-H200 SD Door Replacement: 步骤 2 中的图像 1,1
    • Using a screwdriver, remove the two 6mm screws on the bottom.
    • Using a screwdriver, remove the four 3mm screws on the bottom.
  3. Sony Cyber-shot DSC-H200 SD Door Replacement: 步骤 3 中的图像 1,1
    • Open the SD Door, unscrew and remove the single 6mm screw closest to "PUSH IN/OUT" under the SD card slot.
  4. Sony Cyber-shot DSC-H200 SD Door Replacement: 步骤 4 中的图像 1,2 Sony Cyber-shot DSC-H200 SD Door Replacement: 步骤 4 中的图像 2,2
    • Using the blue plastic opening tools, remove the back panel (the LCD and motherboard are exposed).
  5. Sony Cyber-shot DSC-H200 SD Door Replacement: 步骤 5 中的图像 1,2 Sony Cyber-shot DSC-H200 SD Door Replacement: 步骤 5 中的图像 2,2
    • Using a screwdriver, remove the three 4mm screws that attach the LCD to the camera motherboard (The LCD is contained in a holding plate, attached to the motherboard with a ribbon cable).
    • Using the blue plastic opening tool remove the LCD Screen from the motherboard.
  6. Sony Cyber-shot DSC-H200 SD Door Replacement: 步骤 6 中的图像 1,1
    • Using a screwdriver, remove the single 4mm screw at the bottom of the holding plate.
  7. Sony Cyber-shot DSC-H200 SD Door Replacement: 步骤 7 中的图像 1,1
    • Lift the holding plate away from the motherboard and set aside (the pin attaching the door to the body is now accessible).
  8. Sony Cyber-shot DSC-H200 SD Door Replacement: 步骤 8 中的图像 1,2 Sony Cyber-shot DSC-H200 SD Door Replacement: 步骤 8 中的图像 2,2
    • Using tweezers remove the pin that attaches the door to the body.
  9. Sony Cyber-shot DSC-H200 SD Door Replacement: 步骤 9 中的图像 1,1
    • Remove the door.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 1,543
