跳转到主内容
Sony Cyber-shot DSC-H200 LCD Screen Replacement
你所需要的
  1. Sony Cyber-shot DSC-H200 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,3 Sony Cyber-shot DSC-H200 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 2,3 Sony Cyber-shot DSC-H200 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 3,3
    • Using a screwdriver, remove the five 6mm screws located on the back panel.
    • Using a screwdriver, remove the two 3mm screws located on the back panel.
  2. Sony Cyber-shot DSC-H200 LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Using a screwdriver, remove one 6mm screw on the front panel.
    • Using a screwdriver, remove two 3mm screws on the front panel.
  3. Sony Cyber-shot DSC-H200 LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Open the SD Door, unscrew and remove the single 6mm screw closest to "PUSH IN/OUT" under the SD card slot.
  4. Sony Cyber-shot DSC-H200 LCD Screen Replacement: 步骤 4 中的图像 1,2 Sony Cyber-shot DSC-H200 LCD Screen Replacement: 步骤 4 中的图像 2,2
    • Remove the back panel (the LCD and motherboard are exposed).
  5. Sony Cyber-shot DSC-H200 LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Using a screwdriver, remove the three 4mm screws that attach the LCD to the camera motherboard. (The LCD is contained in a holding plate, attached to the motherboard with a ribbon cable.)
  6. Sony Cyber-shot DSC-H200 LCD Screen Replacement: 步骤 6 中的图像 1,1
    • Using a screwdriver, remove the single 4mm screw at the bottom of the holding plate.
  7. Sony Cyber-shot DSC-H200 LCD Screen Replacement: 步骤 7 中的图像 1,2 Sony Cyber-shot DSC-H200 LCD Screen Replacement: 步骤 7 中的图像 2,2
    • Lift the holding plate away from the motherboard and set aside.
  8. Sony Cyber-shot DSC-H200 LCD Screen Replacement: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Using tweezers, open the LCD ribbon port by lifting the black hinge. (The LCD ribbon cable will detach.)
  9. Sony Cyber-shot DSC-H200 LCD Screen Replacement: 步骤 9 中的图像 1,3 Sony Cyber-shot DSC-H200 LCD Screen Replacement: 步骤 9 中的图像 2,3 Sony Cyber-shot DSC-H200 LCD Screen Replacement: 步骤 9 中的图像 3,3
    • Using tweezers, remove the LCD with the ribbon cable and set aside.
结论
一条评论
Where can you purchase a new replacement monitor?
Butch Sullivan - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 24
总计 2,536
