跳转到主内容
Sony Cyber-shot DSC-H20 Screen Replacement
你所需要的
  1. Sony Cyber-shot DSC-H20 Screen Replacement, Screen: 步骤 1 中的图像 1,2 Sony Cyber-shot DSC-H20 Screen Replacement, Screen: 步骤 1 中的图像 2,2
    • Slide open the battery cover and remove the battery and the Memory Stick Duo.
    • Return the battery cover to its closed position.
  2. Sony Cyber-shot DSC-H20 Screen Replacement: 步骤 2 中的图像 1,1
    • Remove all three screws from the bottom of the camera.
  3. Sony Cyber-shot DSC-H20 Screen Replacement: 步骤 3 中的图像 1,2 Sony Cyber-shot DSC-H20 Screen Replacement: 步骤 3 中的图像 2,2
    • Remove the screws on the left and right sides of the camera.
  4. Sony Cyber-shot DSC-H20 Screen Replacement: 步骤 4 中的图像 1,3 Sony Cyber-shot DSC-H20 Screen Replacement: 步骤 4 中的图像 2,3 Sony Cyber-shot DSC-H20 Screen Replacement: 步骤 4 中的图像 3,3
    • Press down on the flash cover to raise the flash.
    • Remove both screws that hold the flash cover to the body of the camera.
  5. Sony Cyber-shot DSC-H20 Screen Replacement: 步骤 5 中的图像 1,1
    • Place the camera upside down with the battery port positioned upward.
    • Slide open the battery port.
  6. Sony Cyber-shot DSC-H20 Screen Replacement: 步骤 6 中的图像 1,3 Sony Cyber-shot DSC-H20 Screen Replacement: 步骤 6 中的图像 2,3 Sony Cyber-shot DSC-H20 Screen Replacement: 步骤 6 中的图像 3,3
    • Pry the front cover of the camera off with the plastic opening tool.
  7. Sony Cyber-shot DSC-H20 Screen Replacement: 步骤 7 中的图像 1,1
    • Remove the power shutter unit.
  8. Sony Cyber-shot DSC-H20 Screen Replacement: 步骤 8 中的图像 1,2 Sony Cyber-shot DSC-H20 Screen Replacement: 步骤 8 中的图像 2,2
    • Unscrew the screw located at the back left corner of the flash component.
    • Set the flash component aside.
  9. Sony Cyber-shot DSC-H20 Screen Replacement: 步骤 9 中的图像 1,1
    • Remove the two screws from the bottom of the motherboard.
  10. Sony Cyber-shot DSC-H20 Screen Replacement: 步骤 10 中的图像 1,1
    • Use the plastic opening tool to assist you in separating the metal frame from the back cover of the camera.
  11. Sony Cyber-shot DSC-H20 Screen Replacement: 步骤 11 中的图像 1,2 Sony Cyber-shot DSC-H20 Screen Replacement: 步骤 11 中的图像 2,2
    • Flip the metal frame over to the left side of the camera and onto the surface on which you are working.
  12. Sony Cyber-shot DSC-H20 Screen Replacement: 步骤 12 中的图像 1,2 Sony Cyber-shot DSC-H20 Screen Replacement: 步骤 12 中的图像 2,2
    • Now remove the LCD screen by bringing the back cover over to the left so that the LCD screen falls into your hand.
结论
2等其他人完成本指南。
Rachel Payne
于02/23/15注册
386 声望
创作了2篇指南
团队
USF Tampa, Team 1-1, Leahy Winter 2015 USF Tampa, Team 1-1, Leahy Winter 2015 的会员
USFT-LEAHY-W15S1G1
3 名成员
创作了10篇指南
一条评论
Thank you so much. I could successfully open the camera and got the LCD display out. But I couldn't find out how to replace the LCD, I wanted to mean where to open the LCD cable?
ummejamil - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 19
总计 1,959
