跳转到主内容
Sony Cyber-shot DSC-H20 Lens Assembly Replacement
你所需要的
  1. Sony Cyber-shot DSC-H20 Lens Assembly Replacement, Lens Assembly: 步骤 1 中的图像 1,2 Sony Cyber-shot DSC-H20 Lens Assembly Replacement, Lens Assembly: 步骤 1 中的图像 2,2
    • Slide open the battery cover and remove the battery and the Memory Stick Duo.
    • Return the battery cover to its closed position.
  2. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: 步骤 2 中的图像 1,1
    • Remove all three screws from the bottom of the camera.
  3. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: 步骤 3 中的图像 1,2 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: 步骤 3 中的图像 2,2
    • Remove the screws on the left and right sides of the camera.
  4. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: 步骤 4 中的图像 1,3 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: 步骤 4 中的图像 2,3 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: 步骤 4 中的图像 3,3
    • Press down on the flash cover to raise the flash.
    • Remove both screws that hold the flash cover to the body of the camera.
  5. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: 步骤 5 中的图像 1,1
    • Place the camera upside down with the battery port positioned upward and the battery port open.
  6. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: 步骤 6 中的图像 1,3 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: 步骤 6 中的图像 2,3 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: 步骤 6 中的图像 3,3
    • Pry the front cover of the camera off with the plastic opening tool.
  7. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: 步骤 7 中的图像 1,1
    • Remove the power shutter unit
  8. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: 步骤 8 中的图像 1,2 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: 步骤 8 中的图像 2,2
    • Unscrew the screw located at the back left corner of the flash component.
    • Set the flash component aside.
  9. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: 步骤 9 中的图像 1,2 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: 步骤 9 中的图像 2,2
    • Lift up the gray plastic facing in order to uncover the motherboard and the ribbon cable ports.
  10. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: 步骤 10 中的图像 1,2 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: 步骤 10 中的图像 2,2
    • Carefully flip up the three black clasps holding the lens cables to the motherboard.
    • Slide the cables from the ports.
  11. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: 步骤 11 中的图像 1,1
    • Lift the lens and attached ribbon cables from the camera in order to switch this lens with a new one.
结论
另外一个人完成了本指南。
Rachel Payne
于02/23/15注册
386 声望
创作了2篇指南
团队
USF Tampa, Team 1-1, Leahy Winter 2015 USF Tampa, Team 1-1, Leahy Winter 2015 的会员
USFT-LEAHY-W15S1G1
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 38
总计 2,685
