跳转到主内容
Sony Cyber-shot DSC-H20 Flash Assembly Replacement
你所需要的
  1. Sony Cyber-shot DSC-H20 Flash Assembly Replacement, Flash Assembly: 步骤 1 中的图像 1,2 Sony Cyber-shot DSC-H20 Flash Assembly Replacement, Flash Assembly: 步骤 1 中的图像 2,2
    • Slide open the battery cover and remove the battery and the Memory Stick Duo.
    • Return the battery cover to its closed position.
  2. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: 步骤 2 中的图像 1,1
    • Remove all three screws from the bottom of the camera.
  3. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: 步骤 3 中的图像 1,2 Sony Cyber-shot DSC-H20 Flash Assembly Replacement: 步骤 3 中的图像 2,2
    • Remove the screws on the left and right sides of the camera.
  4. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: 步骤 4 中的图像 1,3 Sony Cyber-shot DSC-H20 Flash Assembly Replacement: 步骤 4 中的图像 2,3 Sony Cyber-shot DSC-H20 Flash Assembly Replacement: 步骤 4 中的图像 3,3
    • Press down on the flash cover to raise the flash.
    • Remove both screws that hold the flash cover to the body of the camera.
  5. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: 步骤 5 中的图像 1,2 Sony Cyber-shot DSC-H20 Flash Assembly Replacement: 步骤 5 中的图像 2,2
    • Place the camera upside down with the battery port positioned upward.
    • Slide open the battery port.
  6. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: 步骤 6 中的图像 1,3 Sony Cyber-shot DSC-H20 Flash Assembly Replacement: 步骤 6 中的图像 2,3 Sony Cyber-shot DSC-H20 Flash Assembly Replacement: 步骤 6 中的图像 3,3
    • Pry the front cover of the camera off with the plastic opening tool.
  7. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: 步骤 7 中的图像 1,1
    • Remove the power shutter unit
  8. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: 步骤 8 中的图像 1,2 Sony Cyber-shot DSC-H20 Flash Assembly Replacement: 步骤 8 中的图像 2,2
    • Unscrew the screw located at the back left corner of the flash component.
    • Set the flash component aside.
结论
另外一个人完成了本指南。
团队
USF Tampa, Team 1-1, Leahy Winter 2015 USF Tampa, Team 1-1, Leahy Winter 2015 的会员
USFT-LEAHY-W15S1G1
3 名成员
创作了10篇指南
一条评论
how to bye power sutter unit
aloke mondal - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 20
总计 1,392
