跳转到主内容
Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement
你所需要的
  1. Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement, Micro-USB Port: 步骤 1 中的图像 1,3 Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement, Micro-USB Port: 步骤 1 中的图像 2,3 Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement, Micro-USB Port: 步骤 1 中的图像 3,3
    • Remove the battery before beginning.
    • Remove the three screws from the side of the lens using a JIS #000 screwdriver.
    • Remove the longer single screw from the bottom of the lens using a JIS #000 screwdriver.
  2. Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: 步骤 2 中的图像 1,2 Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: 步骤 2 中的图像 2,2
    • Remove the housing over the lens circuit board.
    • When removing the housing from over the circuit board, be cautious of static when touching the circuit board as to not fry any necessary components.
  3. Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: 步骤 3 中的图像 1,1
    • Unplug the micro-USB type B port from the main circuit board in the lens.
    • When handling the flex cable, be careful as to not destroy this delicate part and cause damage to other components.
  4. Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: 步骤 4 中的图像 1,2 Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: 步骤 4 中的图像 2,2
    • Set the camera aside.
    • Remove the two JIS #000 screws connecting the micro-USB type B port to the housing frame.
  5. Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: 步骤 5 中的图像 1,3 Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: 步骤 5 中的图像 2,3 Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: 步骤 5 中的图像 3,3
    • Remove the damaged micro-USB type B port by lightly pulling near the cable connector.
    • Remove the micro-USB port from the case and replace it with a new micro-USB type B port.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 22
总计 930
