跳转到主内容
Sony Cyber-Shot DSC-W830 Button Board Replacement
你所需要的
  1. Sony Cyber-Shot DSC-W830 Button Board Replacement, Battery: 步骤 1 中的图像 1,1
    • Slide the lock at the bottom of the camera to "Open".
    • The door to the battery pack is spring loaded.
  2. Sony Cyber-Shot DSC-W830 Button Board Replacement: 步骤 2 中的图像 1,1
    • Slide the blue clip up and away from the battery.
  3. Sony Cyber-Shot DSC-W830 Button Board Replacement: 步骤 3 中的图像 1,1
    • Remove the battery.
  4. Sony Cyber-Shot DSC-W830 Button Board Replacement, Front and Back Panel: 步骤 4 中的图像 1,3 Sony Cyber-Shot DSC-W830 Button Board Replacement, Front and Back Panel: 步骤 4 中的图像 2,3 Sony Cyber-Shot DSC-W830 Button Board Replacement, Front and Back Panel: 步骤 4 中的图像 3,3
    • Remove the six 3.5mm Phillips #000 screws.
    • Rotate the lock away from the camera.
  5. Sony Cyber-Shot DSC-W830 Button Board Replacement: 步骤 5 中的图像 1,3 Sony Cyber-Shot DSC-W830 Button Board Replacement: 步骤 5 中的图像 2,3 Sony Cyber-Shot DSC-W830 Button Board Replacement: 步骤 5 中的图像 3,3
    • Pry the device open with the plastic opening tool.
    • There are two clips that help prevent the front panel from separating.
  6. Sony Cyber-Shot DSC-W830 Button Board Replacement: 步骤 6 中的图像 1,3 Sony Cyber-Shot DSC-W830 Button Board Replacement: 步骤 6 中的图像 2,3 Sony Cyber-Shot DSC-W830 Button Board Replacement: 步骤 6 中的图像 3,3
    • Remove the two plastic spacers between the front and the back panels.
    • The spacers may fall out when removing the panels.
    • Carefully remove the back panel.
  7. Sony Cyber-Shot DSC-W830 Button Board Replacement, Button Board: 步骤 7 中的图像 1,2 Sony Cyber-Shot DSC-W830 Button Board Replacement, Button Board: 步骤 7 中的图像 2,2
    • Gently release the button board from the clips.
    • Be careful when lifting the button board; the ribbon cable will still be attached.
  8. Sony Cyber-Shot DSC-W830 Button Board Replacement: 步骤 8 中的图像 1,2 Sony Cyber-Shot DSC-W830 Button Board Replacement: 步骤 8 中的图像 2,2
    • Disconnect the no-fuss ribbon cable by gently pulling it out of the button board.
结论
另外一个人完成了本指南。
Addyson Salalila
于09/15/16注册
316 声望
创作了2篇指南
团队
USF Tampa, Team 17-1, Blackwell Fall 2016 USF Tampa, Team 17-1, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S17G1
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 18
总计 1,720
