跳转到主内容
Sony Cyber-Shot DSC-W170 Top Panel Replacement
你所需要的
  1. Sony Cyber-Shot DSC-W170 Top Panel Replacement, LCD Panel Assembly: 步骤 1 中的图像 1,3 Sony Cyber-Shot DSC-W170 Top Panel Replacement, LCD Panel Assembly: 步骤 1 中的图像 2,3 Sony Cyber-Shot DSC-W170 Top Panel Replacement, LCD Panel Assembly: 步骤 1 中的图像 3,3
    • Be sure to remove the battery before performing this task.
    • Remove the five 4 mm screws with a Phillips #000 screwdriver.
  2. Sony Cyber-Shot DSC-W170 Top Panel Replacement: 步骤 2 中的图像 1,1
    • Use an opening pick to pry the LCD panel open.
  3. Sony Cyber-Shot DSC-W170 Top Panel Replacement: 步骤 3 中的图像 1,1
    • Gently remove the LCD panel from the rest of the camera.
  4. Sony Cyber-Shot DSC-W170 Top Panel Replacement, Front Panel: 步骤 4 中的图像 1,3 Sony Cyber-Shot DSC-W170 Top Panel Replacement, Front Panel: 步骤 4 中的图像 2,3 Sony Cyber-Shot DSC-W170 Top Panel Replacement, Front Panel: 步骤 4 中的图像 3,3
    • Remove the three 4 mm screws with a Phillips #000 screwdriver.
  5. Sony Cyber-Shot DSC-W170 Top Panel Replacement: 步骤 5 中的图像 1,1
    • Gently open the front panel and remove it from the rest of the camera.
  6. Sony Cyber-Shot DSC-W170 Top Panel Replacement, LCD: 步骤 6 中的图像 1,2 Sony Cyber-Shot DSC-W170 Top Panel Replacement, LCD: 步骤 6 中的图像 2,2
    • Remove the first side panel to the left of the LCD.
    • Remove the 4 mm screw from the other side panel to the right of the LCD with a Phillips #000 screwdriver.
  7. Sony Cyber-Shot DSC-W170 Top Panel Replacement: 步骤 7 中的图像 1,3 Sony Cyber-Shot DSC-W170 Top Panel Replacement: 步骤 7 中的图像 2,3 Sony Cyber-Shot DSC-W170 Top Panel Replacement: 步骤 7 中的图像 3,3
    • Gently, lift the LCD and carefully open the camera to disconnect the LCD ribbon cable from the motherboard.
  8. Sony Cyber-Shot DSC-W170 Top Panel Replacement: 步骤 8 中的图像 1,2 Sony Cyber-Shot DSC-W170 Top Panel Replacement: 步骤 8 中的图像 2,2
    • Gently push the connector through the hole to separate the LCD from the metal casing.
  9. Sony Cyber-Shot DSC-W170 Top Panel Replacement, Top Panel: 步骤 9 中的图像 1,2 Sony Cyber-Shot DSC-W170 Top Panel Replacement, Top Panel: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Lift up the black bar on the top flat ribbon cable with tweezers.
    • Gently pull the flat ribbon cable until it disconnects from the lens assembly.
    • Be gentle when dealing with the flat ribbon cable.
  10. Sony Cyber-Shot DSC-W170 Top Panel Replacement: 步骤 10 中的图像 1,3 Sony Cyber-Shot DSC-W170 Top Panel Replacement: 步骤 10 中的图像 2,3 Sony Cyber-Shot DSC-W170 Top Panel Replacement: 步骤 10 中的图像 3,3
    • Remove the six 4 mm screws from the lens assembly with a Phillips #000 screwdriver.
  11. Sony Cyber-Shot DSC-W170 Top Panel Replacement: 步骤 11 中的图像 1,1
    • Lift the two flat ribbon cables with tweezers.
  12. Sony Cyber-Shot DSC-W170 Top Panel Replacement: 步骤 12 中的图像 1,1
    • Peel back the flash assembly on the back of the lens.
    • Remove the two 4 mm screws with a Phillips #000 screwdriver.
  13. Sony Cyber-Shot DSC-W170 Top Panel Replacement: 步骤 13 中的图像 1,1
    • Pull out the battery from the side and remove the white tape from the battery assembly with tweezers.
  14. Sony Cyber-Shot DSC-W170 Top Panel Replacement: 步骤 14 中的图像 1,2 Sony Cyber-Shot DSC-W170 Top Panel Replacement: 步骤 14 中的图像 2,2
    • Disconnect the flat ribbon cable that connects the motherboard to the lens assembly with tweezers.
  15. Sony Cyber-Shot DSC-W170 Top Panel Replacement: 步骤 15 中的图像 1,1
    • Push out the lens assembly very gently.
  16. Sony Cyber-Shot DSC-W170 Top Panel Replacement: 步骤 16 中的图像 1,1
    • Remove the 4 mm screw from the bottom side of the top panel with a Phillips #000 screwdriver.
  17. Sony Cyber-Shot DSC-W170 Top Panel Replacement: 步骤 17 中的图像 1,1
    • Remove the silver 4 mm screw with a Phillips #000 screwdriver from the silver bracket connected to the motherboard.
  18. Sony Cyber-Shot DSC-W170 Top Panel Replacement: 步骤 18 中的图像 1,1
    • Pull the top panel off gently.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 53
