跳转到主内容
Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement
你所需要的
  1. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement, Battery: 步骤 1 中的图像 1,2 Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement, Battery: 步骤 1 中的图像 2,2
    • Using your finger, slide the release catch to unlock the battery/memory card cover.
  2. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: 步骤 2 中的图像 1,2 Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: 步骤 2 中的图像 2,2
    • Open the battery/memory card door.
  3. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: 步骤 3 中的图像 1,2 Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: 步骤 3 中的图像 2,2
    • Push the battery eject lever to free the battery.
  4. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: 步骤 4 中的图像 1,1
    • Remove the battery from the device.
  5. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement, Battery/Memory Card Door Seal: 步骤 5 中的图像 1,1
    • Using a Phillips #00 screwdriver, remove the two 2mm screws on the battery/memory card cover seal.
  6. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: 步骤 6 中的图像 1,1
    • Using your fingers, remove the battery/memory card door seal.
结论
3条评论
hi sir do you have battery lock for replacement ?
John Anthony Geronez - 回复
the Cyber shot by Sony has a lousy battery door it breaks very easily it's made of cheap plastic do you have any replacements for it?
SHELIAH HIPPS - 回复
Where can I get the door catch - is it still available?
sid123 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 18
总计 1,646
