简介
Before use underwater it's important to ensure that the device is properly sealed. Otherwise, the device will likely be seriously damaged. If the battery/memory card cover seal is damaged, broken, or not properly sealing the device to prevent it from taking in water or other hazards, then it needs to be replaced before the camera is used underwater.
你所需要的
Using a Phillips #00 screwdriver, remove the two 2mm screws on the battery/memory card cover seal.
3条评论
hi sir do you have battery lock for replacement ?
the Cyber shot by Sony has a lousy battery door it breaks very easily it's made of cheap plastic do you have any replacements for it?
