简介
In order for the device to work underwater without risk of damage, it must be properly sealed. If the outer shell is damaged or won't properly seal, then its ability to perform underwater without receiving potentially permanent damage is severely reduced.
你所需要的
Using a Phillips #00 screwdriver, remove one black 2 2/5mm screw that is located next to the wrist band loop.
Using a Phillips #00 screwdriver, remove one silver 3mm screw located on the front side of the camera.
Using a Phillips #00 screwdriver, remove one silver 5 2/5mm screw located on the front side of the camera
Using a Phillips #00 screwdriver, remove one black 2 1/2mm screw located on the front side of the camera.
