跳转到主内容
Sony Cyber-Shot DSC-TX30 Back Casing Replacement
你所需要的
  1. Sony Cyber-Shot DSC-TX30 Back Casing Replacement, Battery: 步骤 1 中的图像 1,2 Sony Cyber-Shot DSC-TX30 Back Casing Replacement, Battery: 步骤 1 中的图像 2,2
    • Using your finger, slide the release catch to unlock the battery/memory card cover.
  2. Sony Cyber-Shot DSC-TX30 Back Casing Replacement: 步骤 2 中的图像 1,2 Sony Cyber-Shot DSC-TX30 Back Casing Replacement: 步骤 2 中的图像 2,2
    • Open the battery/memory card door.
  3. Sony Cyber-Shot DSC-TX30 Back Casing Replacement: 步骤 3 中的图像 1,2 Sony Cyber-Shot DSC-TX30 Back Casing Replacement: 步骤 3 中的图像 2,2
    • Push the battery eject lever to free the battery.
  4. Sony Cyber-Shot DSC-TX30 Back Casing Replacement: 步骤 4 中的图像 1,1
    • Remove the battery from the device.
  5. Sony Cyber-Shot DSC-TX30 Back Casing Replacement, Outer Shell: 步骤 5 中的图像 1,1
    • Using a Phillips #00 screwdriver, remove one black 2 2/5mm screw that is located next to the wrist band loop.
  6. Sony Cyber-Shot DSC-TX30 Back Casing Replacement: 步骤 6 中的图像 1,1
    • Using the plastic opening tool, separate the edge-casing from the rest of the camera.
  7. Sony Cyber-Shot DSC-TX30 Back Casing Replacement: 步骤 7 中的图像 1,2 Sony Cyber-Shot DSC-TX30 Back Casing Replacement: 步骤 7 中的图像 2,2
    • Pull the edge-casing off of the camera.
  8. Sony Cyber-Shot DSC-TX30 Back Casing Replacement: 步骤 8 中的图像 1,1
    • Using a Phillips #00 screwdriver, remove one silver 3mm screw located on the front side of the camera.
    • Using a Phillips #00 screwdriver, remove one silver 5 2/5mm screw located on the front side of the camera
    • Using a Phillips #00 screwdriver, remove one black 2 1/2mm screw located on the front side of the camera.
  9. Sony Cyber-Shot DSC-TX30 Back Casing Replacement: 步骤 9 中的图像 1,1
    • Using a Phillips #00 screwdriver, remove one 2 1/2mm screw located near the wrist strap.
  10. Sony Cyber-Shot DSC-TX30 Back Casing Replacement: 步骤 10 中的图像 1,1
    • Using a Phillips #00 screwdriver remove one black 2 2/5mm screw near the tripod slot on the bottom of the casing.
  11. Sony Cyber-Shot DSC-TX30 Back Casing Replacement: 步骤 11 中的图像 1,1
    • Using a Phillips #00 screwdriver remove the two 2 2/5mm black screws from the side of the camera opposite of the wrist strap
  12. Sony Cyber-Shot DSC-TX30 Back Casing Replacement: 步骤 12 中的图像 1,2 Sony Cyber-Shot DSC-TX30 Back Casing Replacement: 步骤 12 中的图像 2,2
    • Using the plastic opening tool, open the device's outer shell.
  13. Sony Cyber-Shot DSC-TX30 Back Casing Replacement: 步骤 13 中的图像 1,2 Sony Cyber-Shot DSC-TX30 Back Casing Replacement: 步骤 13 中的图像 2,2
    • Remove the front casing of the device.
  14. Sony Cyber-Shot DSC-TX30 Back Casing Replacement, Back Casing: 步骤 14 中的图像 1,3 Sony Cyber-Shot DSC-TX30 Back Casing Replacement, Back Casing: 步骤 14 中的图像 2,3 Sony Cyber-Shot DSC-TX30 Back Casing Replacement, Back Casing: 步骤 14 中的图像 3,3
    • Using the plastic opening tool, remove the back casing of the device.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 865
