跳转到主内容
Sony Cyber-Shot DSC-S90 Flash Replacement
你所需要的
  1. Sony Cyber-Shot DSC-S90 Flash Replacement, Batteries: 步骤 1 中的图像 1,2 Sony Cyber-Shot DSC-S90 Flash Replacement, Batteries: 步骤 1 中的图像 2,2
    • Hold down the "open"button (gray oval with arrow pointing upwards) on the battery port door.
    • While holding the button downwards, slide the door upwards to unlock and open the door.
  2. Sony Cyber-Shot DSC-S90 Flash Replacement: 步骤 2 中的图像 1,1
    • Pull open the door and allow the batteries to fall out.
  3. Sony Cyber-Shot DSC-S90 Flash Replacement, Back Case: 步骤 3 中的图像 1,2 Sony Cyber-Shot DSC-S90 Flash Replacement, Back Case: 步骤 3 中的图像 2,2
    • Remove the 2mm Phillips #00 screw under the battery port door.
    • Remove the 2mm Phillips #00 screw towards the right of the bottom-side of the camera.
  4. Sony Cyber-Shot DSC-S90 Flash Replacement: 步骤 4 中的图像 1,2 Sony Cyber-Shot DSC-S90 Flash Replacement: 步骤 4 中的图像 2,2
    • Remove the two 2mm Phillips #00 screws (one on each side of the camera).
  5. Sony Cyber-Shot DSC-S90 Flash Replacement: 步骤 5 中的图像 1,2 Sony Cyber-Shot DSC-S90 Flash Replacement: 步骤 5 中的图像 2,2
    • Use an opening tool to unlock the front case from the main body of the camera. Use the tool on the right side and bottom of the camera with the LCD screen facing you.
  6. Sony Cyber-Shot DSC-S90 Flash Replacement: 步骤 6 中的图像 1,1
    • Pull apart the back case from the main body of the camera.
  7. Sony Cyber-Shot DSC-S90 Flash Replacement, Front Case: 步骤 7 中的图像 1,1
    • Use an opening tool to unlock the front case from the main body of the camera. Use the tool on the top of the camera.
  8. Sony Cyber-Shot DSC-S90 Flash Replacement: 步骤 8 中的图像 1,1
    • Pull apart the front case from the main body of the camera.
  9. Sony Cyber-Shot DSC-S90 Flash Replacement, Top/Side Case: 步骤 9 中的图像 1,3 Sony Cyber-Shot DSC-S90 Flash Replacement, Top/Side Case: 步骤 9 中的图像 2,3 Sony Cyber-Shot DSC-S90 Flash Replacement, Top/Side Case: 步骤 9 中的图像 3,3
    • Release all clips and latches keeping the casing in place using a spudger, opening tool, or screwdriver.
  10. Sony Cyber-Shot DSC-S90 Flash Replacement: 步骤 10 中的图像 1,1
    • Now the casing can be removed after all latches have been undone.
  11. Sony Cyber-Shot DSC-S90 Flash Replacement, Battery Terminal: 步骤 11 中的图像 1,3 Sony Cyber-Shot DSC-S90 Flash Replacement, Battery Terminal: 步骤 11 中的图像 2,3 Sony Cyber-Shot DSC-S90 Flash Replacement, Battery Terminal: 步骤 11 中的图像 3,3
    • Disconnect the ribbon cables on top of the battery terminal using a spudger or screwdriver.
  12. Sony Cyber-Shot DSC-S90 Flash Replacement: 步骤 12 中的图像 1,1
    • Disconnect the remaining ribbon cable on the side of the camera using a spudger or screwdriver.
  13. Sony Cyber-Shot DSC-S90 Flash Replacement: 步骤 13 中的图像 1,1
    • Use a spudger or screwdriver to unhinge the clips. This releases the battery terminal.
  14. Sony Cyber-Shot DSC-S90 Flash Replacement: 步骤 14 中的图像 1,1
    • Once the battery terminal is unclipped, pull this ribbon cable out with a spudger or screwdriver to finish freeing the battery terminal.
  15. Sony Cyber-Shot DSC-S90 Flash Replacement: 步骤 15 中的图像 1,1
    • Now the battery terminal can be separated from the main body of the camera.
  16. Sony Cyber-Shot DSC-S90 Flash Replacement, Motherboard: 步骤 16 中的图像 1,3 Sony Cyber-Shot DSC-S90 Flash Replacement, Motherboard: 步骤 16 中的图像 2,3 Sony Cyber-Shot DSC-S90 Flash Replacement, Motherboard: 步骤 16 中的图像 3,3
    • Disconnect the three pictured ribbon cables using a spudger or screwdriver.
  17. Sony Cyber-Shot DSC-S90 Flash Replacement: 步骤 17 中的图像 1,1
    • Push the clip to the left and lift the motherboard upwards and away from the camera.
  18. Sony Cyber-Shot DSC-S90 Flash Replacement: 步骤 18 中的图像 1,2 Sony Cyber-Shot DSC-S90 Flash Replacement: 步骤 18 中的图像 2,2
    • Disconnect the two ribbon cables using a spudger or screwdriver.
  19. Sony Cyber-Shot DSC-S90 Flash Replacement: 步骤 19 中的图像 1,1
    • Unlatch the clip and lift the motherboard upwards and away from the camera.
  20. Sony Cyber-Shot DSC-S90 Flash Replacement, Flash: 步骤 20 中的图像 1,2 Sony Cyber-Shot DSC-S90 Flash Replacement, Flash: 步骤 20 中的图像 2,2
    • Release the clips on either side of the connector/ribbon cable using a spudger or screwdriver.
  21. Sony Cyber-Shot DSC-S90 Flash Replacement: 步骤 21 中的图像 1,2 Sony Cyber-Shot DSC-S90 Flash Replacement: 步骤 21 中的图像 2,2
    • Release the two clips next to the flash using a spudger or screwdriver.
    • Release the clip holding the LED indicator in place using a spudger or screwdriver.
    • Push the LED indicator upwards from below using a spudger or screwdriver.
  22. Sony Cyber-Shot DSC-S90 Flash Replacement: 步骤 22 中的图像 1,1
    • After all clips have been undone the flash is free to be removed/replaced.
结论
Jonathan Arns
于10/28/19注册
745 声望
创作了8篇指南
团队
UMass Dartmouth, Team S4-G5, Saloman Fall 2019 UMass Dartmouth, Team S4-G5, Saloman Fall 2019 的会员
UMASSD-SALOMAN-F19S4G5
3 名成员
创作了20篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 233
