跳转到主内容
Sony Cyber-Shot DSC-S90 Battery Door Replacement
你所需要的
  1. Sony Cyber-Shot DSC-S90 Battery Door  Replacement, Batteries: 步骤 1 中的图像 1,2 Sony Cyber-Shot DSC-S90 Battery Door  Replacement, Batteries: 步骤 1 中的图像 2,2
    • Hold down the "open"button (gray oval with arrow pointing upwards) on the battery port door.
    • While holding the button downwards, slide the door upwards to unlock and open the door.
  2. Sony Cyber-Shot DSC-S90 Battery Door  Replacement: 步骤 2 中的图像 1,1
    • Pull open the door and allow the batteries to fall out.
  3. Sony Cyber-Shot DSC-S90 Battery Door  Replacement, Back Case: 步骤 3 中的图像 1,2 Sony Cyber-Shot DSC-S90 Battery Door  Replacement, Back Case: 步骤 3 中的图像 2,2
    • Remove the 2mm Phillips #00 screw under the battery port door.
    • Remove the 2mm Phillips #00 screw towards the right of the bottom-side of the camera.
  4. Sony Cyber-Shot DSC-S90 Battery Door  Replacement: 步骤 4 中的图像 1,2 Sony Cyber-Shot DSC-S90 Battery Door  Replacement: 步骤 4 中的图像 2,2
    • Remove the two 2mm Phillips #00 screws (one on each side of the camera).
  5. Sony Cyber-Shot DSC-S90 Battery Door  Replacement: 步骤 5 中的图像 1,2 Sony Cyber-Shot DSC-S90 Battery Door  Replacement: 步骤 5 中的图像 2,2
    • Use an opening tool to unlock the front case from the main body of the camera. Use the tool on the right side and bottom of the camera with the LCD screen facing you.
  6. Sony Cyber-Shot DSC-S90 Battery Door  Replacement: 步骤 6 中的图像 1,1
    • Pull apart the back case from the main body of the camera.
  7. Sony Cyber-Shot DSC-S90 Battery Door  Replacement, Front Case: 步骤 7 中的图像 1,1
    • Use an opening tool to unlock the front case from the main body of the camera. Use the tool on the top of the camera.
  8. Sony Cyber-Shot DSC-S90 Battery Door  Replacement: 步骤 8 中的图像 1,1
    • Pull apart the front case from the main body of the camera.
  9. Sony Cyber-Shot DSC-S90 Battery Door  Replacement, Battery Door: 步骤 9 中的图像 1,1
    • After the front casing is removed, the battery door hinges off freely.
结论
Jonathan Arns
于10/28/19注册
745 声望
创作了8篇指南
团队
UMass Dartmouth, Team S4-G5, Saloman Fall 2019 UMass Dartmouth, Team S4-G5, Saloman Fall 2019 的会员
UMASSD-SALOMAN-F19S4G5
3 名成员
创作了20篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 32
总计 643
