简介
This guide will primarily focus on the replacement and disassembly of the back casing of the Sony Cyber-Shot DSC-S90 camera. This is an easy step by step process that should give you little to no difficulty.
你所需要的
Hold down the "open"button (gray oval with arrow pointing upwards) on the battery port door.
While holding the button downwards, slide the door upwards to unlock and open the door.
Remove the 2mm Phillips #00 screw under the battery port door.
Remove the 2mm Phillips #00 screw towards the right of the bottom-side of the camera.
即将完成!
结论
