跳转到主内容
Sony Cyber-Shot DSC-H1 Lens Replacement
你所需要的
  1. Sony Cyber-Shot DSC-H1 Lens Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Power down the camera and remove the batteries.
  2. Sony Cyber-Shot DSC-H1 Lens Replacement: 步骤 2 中的图像 1,3 Sony Cyber-Shot DSC-H1 Lens Replacement: 步骤 2 中的图像 2,3 Sony Cyber-Shot DSC-H1 Lens Replacement: 步骤 2 中的图像 3,3
    • Using a Phillips #0 screwdriver, remove all of the screws from the back panel casing.
    • There are six 5.22mm long, 3.00mm head diameter screws total.
    • The left side is not shown but there should be 1 screw on that side.
  3. Sony Cyber-Shot DSC-H1 Lens Replacement: 步骤 3 中的图像 1,2 Sony Cyber-Shot DSC-H1 Lens Replacement: 步骤 3 中的图像 2,2
    • Remove the back casing.
    • The casing itself is sturdy so don't be afraid to remove it forcefully.
  4. Sony Cyber-Shot DSC-H1 Lens Replacement, LCD Screen: 步骤 4 中的图像 1,1
    • Take a hold of the right side of the LCD screen and lift it towards the left.
    • The screen is held firm and will require a bit of force to ease it from its housing.
  5. Sony Cyber-Shot DSC-H1 Lens Replacement: 步骤 5 中的图像 1,1
    • Unplug the large conductive tape attached to the screen.
    • Remove the LCD from the device.
  6. Sony Cyber-Shot DSC-H1 Lens Replacement, Lens: 步骤 6 中的图像 1,2 Sony Cyber-Shot DSC-H1 Lens Replacement, Lens: 步骤 6 中的图像 2,2
    • Unscrew and remove the gray backing behind the LCD screen.
  7. Sony Cyber-Shot DSC-H1 Lens Replacement: 步骤 7 中的图像 1,3 Sony Cyber-Shot DSC-H1 Lens Replacement: 步骤 7 中的图像 2,3 Sony Cyber-Shot DSC-H1 Lens Replacement: 步骤 7 中的图像 3,3
    • Using a Phillips #0 screwdriver, unscrew the four 4.24 mm black screws off the blue panel on the right side.
    • Disconnect the white conductive tape.
    • Remove the blue panel.
    • Use tweezers to remove the three conductive tape strips on the right side.
  8. Sony Cyber-Shot DSC-H1 Lens Replacement: 步骤 8 中的图像 1,2 Sony Cyber-Shot DSC-H1 Lens Replacement: 步骤 8 中的图像 2,2
    • Use tweezers to remove the orange conductive tape located below the shutter.
    • Unplug the three ZIF connectors from the motherboard.
  9. Sony Cyber-Shot DSC-H1 Lens Replacement: 步骤 9 中的图像 1,1
    • Flip up the blue overlapping board at the top.
    • Use tweezers to disconnect the remaining connectors.
  10. Sony Cyber-Shot DSC-H1 Lens Replacement: 步骤 10 中的图像 1,1
    • Remove the motherboard and battery pack unit.
  11. Sony Cyber-Shot DSC-H1 Lens Replacement: 步骤 11 中的图像 1,3 Sony Cyber-Shot DSC-H1 Lens Replacement: 步骤 11 中的图像 2,3 Sony Cyber-Shot DSC-H1 Lens Replacement: 步骤 11 中的图像 3,3
    • Use a screwdriver to remove 5 screws on plastic panel.
    • Remove the single screw on the silver panel in the center.
  12. Sony Cyber-Shot DSC-H1 Lens Replacement: 步骤 12 中的图像 1,3 Sony Cyber-Shot DSC-H1 Lens Replacement: 步骤 12 中的图像 2,3 Sony Cyber-Shot DSC-H1 Lens Replacement: 步骤 12 中的图像 3,3
    • Use tweezers to remove the blue control panel.
    • Remove the lens from the camera.
结论
3等其他人完成本指南。
Charlie Pugeda
于03/19/18注册
505 声望
创作了3篇指南
团队
Baylor, Team S5-G4, Williams Spring 2018 Baylor, Team S5-G4, Williams Spring 2018 的会员
BU-WILLIAMS-S18S5G4
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 13
过去 30 天: 20
总计 1,575
