跳转到主内容
Sony Clie PEG-UX50 Tilt Screen Replacement
你所需要的
  1. Sony Clie PEG-UX50 Tilt Screen Replacement, Tilt Screen: 步骤 1 中的图像 1,3 Sony Clie PEG-UX50 Tilt Screen Replacement, Tilt Screen: 步骤 1 中的图像 2,3 Sony Clie PEG-UX50 Tilt Screen Replacement, Tilt Screen: 步骤 1 中的图像 3,3
    • Take off the screws located on the two sides of the tilt screen.
    • Unscrew the screw located at the tilt base of the screen.
  2. Sony Clie PEG-UX50 Tilt Screen Replacement: 步骤 2 中的图像 1,3 Sony Clie PEG-UX50 Tilt Screen Replacement: 步骤 2 中的图像 2,3 Sony Clie PEG-UX50 Tilt Screen Replacement: 步骤 2 中的图像 3,3
    • Gently remove the back plate of the tilt screen by sliding it upward.
    • With caution, lift the wires from the track in the back plate.
  3. Sony Clie PEG-UX50 Tilt Screen Replacement: 步骤 3 中的图像 1,2 Sony Clie PEG-UX50 Tilt Screen Replacement: 步骤 3 中的图像 2,2
    • Disconnect the thin USB cable attached to the Integrated Circuit.
  4. Sony Clie PEG-UX50 Tilt Screen Replacement: 步骤 4 中的图像 1,2 Sony Clie PEG-UX50 Tilt Screen Replacement: 步骤 4 中的图像 2,2
    • Detach the plastic black frame from in between the plate and the LCD.
    • Do not disconnect the display from the board yet.
  5. Sony Clie PEG-UX50 Tilt Screen Replacement: 步骤 5 中的图像 1,1
    • Disconnect the thin connector from the face plate using tweezers.
  6. Sony Clie PEG-UX50 Tilt Screen Replacement: 步骤 6 中的图像 1,1
    • Quickly release and disconnect the thick cable with your hands.
结论
Follow these instructions in reverse order to reassemble your device.
Rishad R Rai
于04/28/11注册
1 声望
撰写一个指南
团队
CSU Los Angeles, Team 1-4, Nelson Spring 2011 CSU Los Angeles, Team 1-4, Nelson Spring 2011 的会员
CSULA-NELSON-S11S1G4
5 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 2,732
