跳转到主内容
Sony Clie PEG-T615C Thumb Dial Replacement
你所需要的
  1. Sony Clie PEG-T615C Thumb Dial Replacement, Thumb Dial: 步骤 1 中的图像 1,1
    • First, place the device with the screen side facing down. Remove the 2 screws from the thumb dial panel located on the upper right hand side.
  2. Sony Clie PEG-T615C Thumb Dial Replacement: 步骤 2 中的图像 1,1
    • Remove the screw directly above the thumb dial panel.
  3. Sony Clie PEG-T615C Thumb Dial Replacement: 步骤 3 中的图像 1,1
    • Remove the screw from thumb dial panel on the right handed side of the device.
  4. Sony Clie PEG-T615C Thumb Dial Replacement: 步骤 4 中的图像 1,1
    • Remove screw from lower right side of the device.
  5. Sony Clie PEG-T615C Thumb Dial Replacement: 步骤 5 中的图像 1,1
    • Remove 1 screw from the lower left side of the device.
  6. Sony Clie PEG-T615C Thumb Dial Replacement: 步骤 6 中的图像 1,1
    • On the bottom of the device, remove both the left and right screws.
  7. Sony Clie PEG-T615C Thumb Dial Replacement: 步骤 7 中的图像 1,1
    • Remove the thumb dial panel by sliding it away from the device.
  8. Sony Clie PEG-T615C Thumb Dial Replacement: 步骤 8 中的图像 1,1
    • Remove the back panel exposing the inside of the device.
  9. Sony Clie PEG-T615C Thumb Dial Replacement: 步骤 9 中的图像 1,1
    • Locate thumb dial on top right side of the board.
  10. Sony Clie PEG-T615C Thumb Dial Replacement: 步骤 10 中的图像 1,1
    • Follow ribbon wire to locate where it plugs into the board. The plug is a flat black square.
  11. Sony Clie PEG-T615C Thumb Dial Replacement: 步骤 11 中的图像 1,1
    • Pull plug straight up to remove from board.
结论
Rob
于10/04/11注册
1 声望
创作了2篇指南
团队
UW Stout, Team 5-6, Zhou Fall 2011 UW Stout, Team 5-6, Zhou Fall 2011 的会员
UWSTOUT-ZHOU-F11S5G6
4 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 17
总计 1,067
