简介
This article will teach the user how to remove an old battery from a Sony Clie PEG-T615C with short and easy-to-follow steps.
配件
无需配件。
  1. Remove two screws from the thumb dial panel on the back of the device.
    • Remove two screws from the thumb dial panel on the back of the device.
  2. Remove one screw from the upper right corner on the back of the device.
    • Remove one screw from the upper right corner on the back of the device.
  3. Remove one screw from the thumb dial panel on the right side of the device.
    • Remove one screw from the thumb dial panel on the right side of the device.
  4. Remove one screw from lower right side of the device.
    • Remove one screw from lower right side of the device.
  5. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  6. Remove one screw from the lower left side of the device.
    • Remove one screw from the lower left side of the device.
  7. Remove two screws from the bottom of the device.
    • Remove two screws from the bottom of the device.
  8. Remove the thumb dial panel by sliding it away from the device.
    • Remove the thumb dial panel by sliding it away from the device.
    • You can do this step earlier, after you remove all of the screws from the thumb drive panel.
  9. Remove the back panel, exposing the inside of the device.
    • Remove the back panel, exposing the inside of the device.
  10. Remove one screw located on the board below the battery.
    • Remove one screw located on the board below the battery.
  11. Unplug the male battery plug on the battery wire from the female battery plug on the board.
    • Unplug the male battery plug on the battery wire from the female battery plug on the board.
  12. Remove the battery by sliding it out of the side of the device.
    • Remove the battery by sliding it out of the side of the device.
结论
Rob
于2011年10月04日注册
1 信誉积分
创作了2篇指南
团队
UW Stout, Team 5-6, Zhou Fall 2011 UW Stout, Team 5-6, Zhou Fall 2011 的会员
UWSTOUT-ZHOU-F11S5G6
4 名成员
创作了2篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 5
总计 1,539
