跳转到主内容
Sony Clie PEG-SL10 Motherboard Replacement
你所需要的
  1. Sony Clie PEG-SL10 Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Remove the six screws holding the case together.
  2. Sony Clie PEG-SL10 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the seven screws holding the motherboard to the device.
  3. Sony Clie PEG-SL10 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Unclip the battery harness power cable from the motherboard.
  4. Sony Clie PEG-SL10 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Unclip the scroll wheel power cable from the motherboard.
  5. Sony Clie PEG-SL10 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Pull the left clip to remove the cable.
  6. Sony Clie PEG-SL10 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Pull out the two clips from the center to remove the power cable.
  7. Sony Clie PEG-SL10 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Rotate the motherboard toward you to show the cables on the opposite side of the motherboard.
  8. Sony Clie PEG-SL10 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Extend both sides of the left clip to remove the power cable.
  9. Sony Clie PEG-SL10 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Pull out the center clip to remove the power cable.
  10. Sony Clie PEG-SL10 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Pull the right clip out to remove the right cable.
  11. Sony Clie PEG-SL10 Motherboard Replacement: 步骤 11 中的图像 1,1
    • The motherboard is removed. To install the new motherboard, follow the directions in reverse.
结论
Emily
于10/18/11注册
3 声望
创作了3篇指南
团队
James Madison, Team 1-4, Allen Fall 2011 James Madison, Team 1-4, Allen Fall 2011 的会员
JMU-ALLEN-F11S1G4
3 名成员
创作了4篇指南
一条评论
I have a full reset whenever I take the battery out to recharge it. Given that all replacement motherboards will be as old as the unit, is there anyway to fix the board (I presume it’s a capacitor or super cell that keeps the charge long enough to swap the battery over normally?). The three cells seem to be soldered onto the board, but I presume could be replaced?
Anyone know of a way to fix this?
Benjamin S. Leveritt - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 7
总计 1,304
