简介
If your device is having trouble reading memory you probably need to replace the memory module. This guide will show you step-by-step how to install a new memory module.
你所需要的
Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
Holding the memory module in place, unscrew the three 0.9mm screws with a Phillips #00 screwdriver.
即将完成!
结论
