跳转到主内容
Sony Clie PEG-NR70 Memory Module Replacement
你所需要的
  1. Sony Clie PEG-NR70 Memory Module Replacement, The Case: 步骤 1 中的图像 1,1
    • Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
    • It may be helpful to set up a piece of paper to keep track of where removed screws came from.
  2. Sony Clie PEG-NR70 Memory Module Replacement: 步骤 2 中的图像 1,1
    • Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
  3. Sony Clie PEG-NR70 Memory Module Replacement: 步骤 3 中的图像 1,2 Sony Clie PEG-NR70 Memory Module Replacement: 步骤 3 中的图像 2,2
    • Unscrew the five 2.5mm screws on the back panel with a Phillips #00 screwdriver.
    • Remove the back panel by lifting it away with your hands.
  4. Sony Clie PEG-NR70 Memory Module Replacement, Memory Module: 步骤 4 中的图像 1,1
    • Holding the memory module in place, unscrew the three 0.9mm screws with a Phillips #00 screwdriver.
  5. Sony Clie PEG-NR70 Memory Module Replacement: 步骤 5 中的图像 1,1
    • Lightly grab the memory module and pull it upwards.
    • Make sure you grab the end closest to the edge of the device. You may have to wiggle the module a bit to get it to come free.
结论
Daniel Soski
于04/18/13注册
57 声望
创作了6篇指南
团队
Cal Poly, Team 14-11, Maness Spring 2013 Cal Poly, Team 14-11, Maness Spring 2013 的会员
CPSU-MANESS-S13S14G11
5 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 554
