跳转到主内容
Sony Clie PEG-NR70 Battery Pack Replacement
你所需要的
  1. Sony Clie PEG-NR70 Battery Pack Replacement, The Case: 步骤 1 中的图像 1,1
    • Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
    • It may be helpful to set up a piece of paper to keep track of where removed screws came from.
  2. Sony Clie PEG-NR70 Battery Pack Replacement: 步骤 2 中的图像 1,1
    • Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
  3. Sony Clie PEG-NR70 Battery Pack Replacement: 步骤 3 中的图像 1,2 Sony Clie PEG-NR70 Battery Pack Replacement: 步骤 3 中的图像 2,2
    • Unscrew the five 2.5mm screws on the back panel with a Phillips #00 screwdriver.
    • Remove the back panel by lifting it away with your hands.
  4. Sony Clie PEG-NR70 Battery Pack Replacement, Battery Pack: 步骤 4 中的图像 1,2 Sony Clie PEG-NR70 Battery Pack Replacement, Battery Pack: 步骤 4 中的图像 2,2
    • Pull up on the black tab on the battery pack to reveal the power cord.
  5. Sony Clie PEG-NR70 Battery Pack Replacement: 步骤 5 中的图像 1,1
    • Disconnect the battery pack from the motherboard by unplugging the power cables. Gently pull the wire toward the bottom of the device.
    • Be careful to not tear the cables! They are very thin.
  6. Sony Clie PEG-NR70 Battery Pack Replacement: 步骤 6 中的图像 1,1
    • Gently peel back the adhesive to completely disconnect the battery pack from device.
结论
3等其他人完成本指南。
Courtney
于04/19/13注册
49 声望
创作了2篇指南
团队
Cal Poly, Team 14-11, Maness Spring 2013 Cal Poly, Team 14-11, Maness Spring 2013 的会员
CPSU-MANESS-S13S14G11
5 名成员
创作了8篇指南
一条评论
Hi, this is really helpful, thank you.
Richard Hancock - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 16
总计 2,156
