跳转到主内容
加入维修社区 - 创建账户
Sony CPF-IP001 Power Plug Replacement
你所需要的
  1. Sony CPF-IP001 Power Plug Replacement, Power Plug: 步骤 1 中的图像 1,3 Sony CPF-IP001 Power Plug Replacement, Power Plug: 步骤 1 中的图像 2,3 Sony CPF-IP001 Power Plug Replacement, Power Plug: 步骤 1 中的图像 3,3
    • The Sony Cradle Audio System will have 14 XXXX type of screws located on the bottom of the device.
    • Using a Phillips #2 screwdriver, remove all 14 screws.
  2. Sony CPF-IP001 Power Plug Replacement: 步骤 2 中的图像 1,3 Sony CPF-IP001 Power Plug Replacement: 步骤 2 中的图像 2,3 Sony CPF-IP001 Power Plug Replacement: 步骤 2 中的图像 3,3
    • Once all of the screws are removed, the cover can be taken off using a metal spudger.
    • There are 8 more XXXX screws holding the circuit board in place that will need to be removed.
    • Once the screws are removed, a plastic spudger can be used to carefully move the circuit board away from the device.
    • There will be 3 wires connected to the opposite side of the circuit board. Be careful not to pull the board out of the device too far and damage these wires.
  3. Sony CPF-IP001 Power Plug Replacement: 步骤 3 中的图像 1,2 Sony CPF-IP001 Power Plug Replacement: 步骤 3 中的图像 2,2
    • The first of the 3 wires can easily be found and is connected to the board via a clip.
    • To remove the clip squeeze the tap and pull it out.
    • There are still 2 more wires connected to the board. Now that the first has been removed the other two can be more easily reached.
  4. Sony CPF-IP001 Power Plug Replacement: 步骤 4 中的图像 1,3 Sony CPF-IP001 Power Plug Replacement: 步骤 4 中的图像 2,3 Sony CPF-IP001 Power Plug Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    • The wire furthest to the left of the device can be removed in the same way that he first was removed. Simply squeeze the clip and pull out.
    • The final wire (furthest to the right) can be carefully removed using a pair of tweezers.
    • Now the circuit board has been completely removed from the device and can be set aside.
  5. Sony CPF-IP001 Power Plug Replacement: 步骤 5 中的图像 1,2 Sony CPF-IP001 Power Plug Replacement: 步骤 5 中的图像 2,2
    • Next the housing for the power switch and power cord must be removed.
    • Remove the 4 XXXX screws using a Phillips #2 screwdriver.
  6. Sony CPF-IP001 Power Plug Replacement: 步骤 6 中的图像 1,3 Sony CPF-IP001 Power Plug Replacement: 步骤 6 中的图像 2,3 Sony CPF-IP001 Power Plug Replacement: 步骤 6 中的图像 3,3
    • Remove these next 6 XXXX screws using a Phillips #2 screwdriver.
    • The housing is now disconnected from the device and can be pulled out from the side.
    • The power housing will come out as a whole unit with the subwoofer air tunnel.
  7. Sony CPF-IP001 Power Plug Replacement: 步骤 7 中的图像 1,1
    • The subwoofer air tunnel can be removed by unscrewing the 2 XXXX screws with a Phillips #2 screwdriver.
结论
Mike Bolton
于04/14/15注册
473 声望
创作了4篇指南
团队
Cal Poly, Team 6-14, Maness Spring 2015 Cal Poly, Team 6-14, Maness Spring 2015 的会员
CPSU-MANESS-S15S6G14
4 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 284
