跳转到主内容
Sony CPF-IP001 Buttons on Main Speaker Replacement
你所需要的
  1. Sony CPF-IP001 Buttons on Main Speaker Replacement, Main Speaker Housing Disassembly: 步骤 1 中的图像 1,1
    • Remove two 6mm Phillips #0 screws.
    • Remove two 7.5 mm Phillips #0 screws.
    • Remove seven 4 mm Phillips #0 screws.
  2. Sony CPF-IP001 Buttons on Main Speaker Replacement: 步骤 2 中的图像 1,3 Sony CPF-IP001 Buttons on Main Speaker Replacement: 步骤 2 中的图像 2,3 Sony CPF-IP001 Buttons on Main Speaker Replacement: 步骤 2 中的图像 3,3
    • Remove six 4 mm Phillips #0 screws from the metal backing.
    • Remove six 5 mm Phillips #0 screws from the metal backing.
    • Using the plastic opening tool, remove the metal plate from the main speaker by gently pulling on it.
  3. Sony CPF-IP001 Buttons on Main Speaker Replacement: 步骤 3 中的图像 1,2 Sony CPF-IP001 Buttons on Main Speaker Replacement: 步骤 3 中的图像 2,2
    • Remove the plastic dock cover by using two fingers to push the attached metal piece forward and slide it out of the holes.
  4. Sony CPF-IP001 Buttons on Main Speaker Replacement: 步骤 4 中的图像 1,3 Sony CPF-IP001 Buttons on Main Speaker Replacement: 步骤 4 中的图像 2,3 Sony CPF-IP001 Buttons on Main Speaker Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    • Using the plastic opening tool, detach the wires connected to the metal plate
    • When disconnecting the wires, be careful not to pull on the wires themselves. Use the plastic opening tool and the connector to disconnect it.
    • Use the plastic opening tool to remove wires connected to the circuit board on the far right.
    • Use the tweezers to remove wires connected to the circuit board in between the two black wires.
    • Use the tweezers to press the release tab on the front and back of the plastic white wire head.
    • Once the tab is pressed on both sides, lift up to slide wire head out of socket.
  5. Sony CPF-IP001 Buttons on Main Speaker Replacement: 步骤 5 中的图像 1,1
    • Remove two 5 mm Phillips #0 screws.
  6. Sony CPF-IP001 Buttons on Main Speaker Replacement: 步骤 6 中的图像 1,3 Sony CPF-IP001 Buttons on Main Speaker Replacement: 步骤 6 中的图像 2,3 Sony CPF-IP001 Buttons on Main Speaker Replacement: 步骤 6 中的图像 3,3
    • Using the metal spudger, loosen the metal cap at the end of the speaker.
    • Slide down the loosened cap to remove it from the end of the speaker.
    • Simultaneously push down on the buttons and slide the speaker out from the casing.
  7. Sony CPF-IP001 Buttons on Main Speaker Replacement, Buttons on Main Speaker: 步骤 7 中的图像 1,3 Sony CPF-IP001 Buttons on Main Speaker Replacement, Buttons on Main Speaker: 步骤 7 中的图像 2,3 Sony CPF-IP001 Buttons on Main Speaker Replacement, Buttons on Main Speaker: 步骤 7 中的图像 3,3
    • Remove two 6 mm Phillips #0 screws.
    • Gently lift the silver buttons up to remove.
  8. Sony CPF-IP001 Buttons on Main Speaker Replacement: 步骤 8 中的图像 1,3 Sony CPF-IP001 Buttons on Main Speaker Replacement: 步骤 8 中的图像 2,3 Sony CPF-IP001 Buttons on Main Speaker Replacement: 步骤 8 中的图像 3,3
    • Using the plastic opening tool, disconnect the white connector from the circuit board.
    • Replace the broken circuit board with a new one.
结论
3等其他人完成本指南。
Cole Stanley
于04/14/15注册
290 声望
撰写一个指南
团队
Cal Poly, Team 6-14, Maness Spring 2015 Cal Poly, Team 6-14, Maness Spring 2015 的会员
CPSU-MANESS-S15S6G14
4 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 9
总计 428
