简介
This guide will demonstrate how to open the radio and remove the speakers.
你所需要的
Press down on the two tabs at the top of the door.
Rotate the door away from the radio, towards you.
Lift the door out of the three smaller tabs on the bottom.
Push the batteries against the spring and pull out using your finger to remove them.
Remove the 6 screws (30 mm in length) with the Phillips #2 Screwdriver from the large holes marked by arrows on the radio.
Remove the 2 screws (10 mm in length) located on the corners of the speaker with the Phillips #2 screwdriver.
Repeat the process for the second speaker if you need to replace both speakers.
另外一个人完成了本指南。
