跳转到主内容
Sony CFS-204 Radio Cassette-Corder Batteries Replacement
你所需要的
  1. Sony CFS-204 Radio Cassette-Corder Batteries Replacement, Batteries: 步骤 1 中的图像 1,1
    • Press down on the two tabs at the top of the door.
    • Rotate the door away from the radio, towards you.
    • Lift the door out of the three smaller tabs on the bottom.
    • Ensure the radio is turned off to avoid the possibility of electric shock.
    • The battery compartment door is not shown.
  2. Sony CFS-204 Radio Cassette-Corder Batteries Replacement, Batteries: 步骤 2 中的图像 1,3 Sony CFS-204 Radio Cassette-Corder Batteries Replacement, Batteries: 步骤 2 中的图像 2,3 Sony CFS-204 Radio Cassette-Corder Batteries Replacement, Batteries: 步骤 2 中的图像 3,3
    • Push the batteries against the spring and pull out using your finger to remove them.
    • To insert the new batteries, push the negative end of the 1st battery against a spring and follow the diagram pictured to insert the batteries in the correct orientation.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 26
总计 1,851
