跳转到主内容
Sony CFD-S70 Disassembly
你所需要的
  1. Sony CFD-S70 Disassembly, Remove the bottom screws: 步骤 1 中的图像 1,3 Sony CFD-S70 Disassembly, Remove the bottom screws: 步骤 1 中的图像 2,3 Sony CFD-S70 Disassembly, Remove the bottom screws: 步骤 1 中的图像 3,3
    • Using a PH2 screwdriver, remove the 5 screws in the holes
    • Don’t forget to remove the two screws circled in green
    • The hole screws can be difficult to remove. Don’t forget to use a magnetized screwdriver
    • The antenna screws can be ignored for now. It’s not important for the disassembly
  2. Sony CFD-S70 Disassembly, Remove the top screws: 步骤 2 中的图像 1,3 Sony CFD-S70 Disassembly, Remove the top screws: 步骤 2 中的图像 2,3 Sony CFD-S70 Disassembly, Remove the top screws: 步骤 2 中的图像 3,3
    • Open the CD cover and remove the two screws using a PH0 screwdriver
    • Move the handle up to unscrew the hole screws using a PH2 screwdriver
    • Be careful around the optical pickup (the small lense)
  3. Sony CFD-S70 Disassembly, Opening the device: 步骤 3 中的图像 1,2 Sony CFD-S70 Disassembly, Opening the device: 步骤 3 中的图像 2,2
    • Turn the device on his back and pull back and up the bottom portion of the device
    • There’s a connector attached, be careful
  4. Sony CFD-S70 Disassembly, Removing a cable: 步骤 4 中的图像 1,1
    • Be careful, the connector is fragile
  5. Sony CFD-S70 Disassembly, Removing and unplugging the main: 步骤 5 中的图像 1,3 Sony CFD-S70 Disassembly, Removing and unplugging the main: 步骤 5 中的图像 2,3 Sony CFD-S70 Disassembly, Removing and unplugging the main: 步骤 5 中的图像 3,3
    • Remove the two screws with a PH2
    • Remove the connector on the left side of the mainboard
    • Stress the right side where there’s the audio connections and pull the main by the left
  6. Sony CFD-S70 Disassembly, Disconnecting connectors: 步骤 6 中的图像 1,2 Sony CFD-S70 Disassembly, Disconnecting connectors: 步骤 6 中的图像 2,2
    • On the bottom of the main, gently disconnect the connector
    • This connector is VERY fragile. Use something to hold it in place
    • Like the connector, remove the Flex cable from the main
    • Also use caution while removing it. It can break/cut very easily
  7. Sony CFD-S70 Disassembly, Disconnecting connectors: 步骤 7 中的图像 1,3 Sony CFD-S70 Disassembly, Disconnecting connectors: 步骤 7 中的图像 2,3 Sony CFD-S70 Disassembly, Disconnecting connectors: 步骤 7 中的图像 3,3
    • Carefully flip the main and disconnect like the others the cables. You can now remove the mainboard
    • Like before, they’re very fragile
  8. Sony CFD-S70 Disassembly, Removing the front: 步骤 8 中的图像 1,2 Sony CFD-S70 Disassembly, Removing the front: 步骤 8 中的图像 2,2
    • Now it’s time to remove the front of the device. There’s two little brackets on each side that is retaining the front
  9. Sony CFD-S70 Disassembly, Pulling the front tabs: 步骤 9 中的图像 1,2 Sony CFD-S70 Disassembly, Pulling the front tabs: 步骤 9 中的图像 2,2
    • Using a flat screwdriver or any other flat and thin tool, pry the outside tabs working your way down and pull the front from the top of the device
    • There’s two little tabs with screw holes. Be careful not to damage them
结论
To reassemble your device, follow these instructions in reverse order. Have fun :D
Maxence Chartre
于05/23/21注册
170 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 33
总计 223
