跳转到主内容
Sony CFD-8 Speaker Replacement
你所需要的
  1. Sony CFD-8 Speaker Replacement, Front Panel: 步骤 1 中的图像 1,3 Sony CFD-8 Speaker Replacement, Front Panel: 步骤 1 中的图像 2,3 Sony CFD-8 Speaker Replacement, Front Panel: 步骤 1 中的图像 3,3
    • Hold the boombox handle at an angle to access the screws behind the CD player.
    • Use a Phillips #1 screwdriver to unscrew the top two 14 mm screws. You may need a flashlight to see the screws.
  2. Sony CFD-8 Speaker Replacement: 步骤 2 中的图像 1,2 Sony CFD-8 Speaker Replacement: 步骤 2 中的图像 2,2
    • Remove four 14 mm screws using a Phillips #1 screwdriver. Two of these screws are at the bottom of the boombox and the other two are on either side of the boombox as highlighted in the related images.
    • All four screws have black arrows (not visible in the photo) indicating their location on the boombox.
  3. Sony CFD-8 Speaker Replacement: 步骤 3 中的图像 1,3 Sony CFD-8 Speaker Replacement: 步骤 3 中的图像 2,3 Sony CFD-8 Speaker Replacement: 步骤 3 中的图像 3,3
    • Gently separate the front panel from the back panel.
    • Remove the two connections holding the front panel to boombox.
    • One connection is located on the upper left hand side of the main circuit board.
    • The other is a large white strip slightly to the right of the cassette player.
    • Do not touch the cylindrical parts on the circuit board. These are capacitors and may deliver a shock!
    • Remove the front panel.
  4. Sony CFD-8 Speaker Replacement, Speaker: 步骤 4 中的图像 1,2 Sony CFD-8 Speaker Replacement, Speaker: 步骤 4 中的图像 2,2
    • Use a 14cm Phillips #1 screwdriver to remove the four respective screws attaching the left and right speakers to the front panel.
  5. Sony CFD-8 Speaker Replacement: 步骤 5 中的图像 1,1
    • Remove the speakers from the front panel.
结论
2等其他人完成本指南。
Liam Kirsh
于10/14/14注册
197 声望
撰写一个指南
团队
Cal Poly, Team 10-38, Amido Fall 2014 Cal Poly, Team 10-38, Amido Fall 2014 的会员
CPSU-AMIDO-F14S10G38
5 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 17
总计 3,337
