跳转到主内容
Sony CFD-8 Motor Belt Replacement
你所需要的
  1. Sony CFD-8 Motor Belt Replacement, Battery: 步骤 1 中的图像 1,3 Sony CFD-8 Motor Belt Replacement, Battery: 步骤 1 中的图像 2,3 Sony CFD-8 Motor Belt Replacement, Battery: 步骤 1 中的图像 3,3
    • Remove the battery cover on the back of the boombox by applying downward pressure to the two clamps.
    • Be sure to unplug the boombox from the wall before attempting to open it for repair.
  2. Sony CFD-8 Motor Belt Replacement: 步骤 2 中的图像 1,2 Sony CFD-8 Motor Belt Replacement: 步骤 2 中的图像 2,2
    • Push against the positive end of each battery. Once it is loose, lift the battery out. Repeat for all six batteries.
    • The top row of batteries have the positive side pointing right. The bottom row of batteries have the positive side pointing left.
  3. Sony CFD-8 Motor Belt Replacement, Front Panel: 步骤 3 中的图像 1,3 Sony CFD-8 Motor Belt Replacement, Front Panel: 步骤 3 中的图像 2,3 Sony CFD-8 Motor Belt Replacement, Front Panel: 步骤 3 中的图像 3,3
    • Hold the boombox handle at an angle to access the screws behind the CD player.
    • Use a Phillips #1 screwdriver to unscrew the top two 14 mm screws. You may need a flashlight to see the screws.
  4. Sony CFD-8 Motor Belt Replacement: 步骤 4 中的图像 1,2 Sony CFD-8 Motor Belt Replacement: 步骤 4 中的图像 2,2
    • Remove four 14 mm screws using a Phillips #1 screwdriver. Two of these screws are at the bottom of the boombox and the other two are on either side of the boombox as highlighted in the related images.
    • All four screws have black arrows (not visible in the photo) indicating their location on the boombox.
  5. Sony CFD-8 Motor Belt Replacement: 步骤 5 中的图像 1,3 Sony CFD-8 Motor Belt Replacement: 步骤 5 中的图像 2,3 Sony CFD-8 Motor Belt Replacement: 步骤 5 中的图像 3,3
    • Gently separate the front panel from the back panel.
    • Remove the two connections holding the front panel to boombox.
    • One connection is located on the upper left hand side of the main circuit board.
    • The other is a large white strip slightly to the right of the cassette player.
    • Do not touch the cylindrical parts on the circuit board. These are capacitors and may deliver a shock!
    • Remove the front panel.
  6. Sony CFD-8 Motor Belt Replacement, Remove Gear Assembly: 步骤 6 中的图像 1,1
    • Unscrew the 3x12 screws circled in the photo using a #1 Phillips screwdriver.
  7. Sony CFD-8 Motor Belt Replacement, Disconnect Wires: 步骤 7 中的图像 1,1
    • Carefully disconnect the wire connection by pulling at its base.
  8. Sony CFD-8 Motor Belt Replacement, Remove Motor: 步骤 8 中的图像 1,3 Sony CFD-8 Motor Belt Replacement, Remove Motor: 步骤 8 中的图像 2,3 Sony CFD-8 Motor Belt Replacement, Remove Motor: 步骤 8 中的图像 3,3
    • Unscrew the 5mm screw shown in the photo.
    • Note the small latch on the side of assembly as you remove the motor.
  9. Sony CFD-8 Motor Belt Replacement, Replace Motor Belt: 步骤 9 中的图像 1,2 Sony CFD-8 Motor Belt Replacement, Replace Motor Belt: 步骤 9 中的图像 2,2
    • Remove the motor belt from its axle.
结论
4等其他人完成本指南。
Wil Gilbreath
于10/14/14注册
205 声望
撰写一个指南
团队
Cal Poly, Team 10-38, Amido Fall 2014 Cal Poly, Team 10-38, Amido Fall 2014 的会员
CPSU-AMIDO-F14S10G38
5 名成员
创作了7篇指南
3条评论
need belt for cassette replace
joe jefferson - 回复
need the belt for the cassette player
joe jefferson - 回复
First, be sure to have a #1 pt screwdriver with at least a 5” shaft(not counting the handle) length. Second, pay attention to where the screws under the handle are located. Third, mark the top of the connectors with a sharpie or such instrument to be sure you are replacing the connector in the correct position.
Don Gunkel - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 59
总计 13,413
