跳转到主内容
Sony CDX-GT540UI Fuse Replacement
  1. Sony CDX-GT540UI Fuse Replacement, Wiring Harness: 步骤 1 中的图像 1,1
    • Locate the clip on the wiring harness.
  2. Sony CDX-GT540UI Fuse Replacement: 步骤 2 中的图像 1,2 Sony CDX-GT540UI Fuse Replacement: 步骤 2 中的图像 2,2
    • Press down on the clip like you would an Ethernet cable.
    • Rock harness side to side, pulling gently towards you until harness detaches.
  3. Sony CDX-GT540UI Fuse Replacement, Fuse: 步骤 3 中的图像 1,1
    • Once you have removed the wiring harness.
    • Locate the fuse.
  4. Sony CDX-GT540UI Fuse Replacement: 步骤 4 中的图像 1,1
    • Using your index finger and thumb on either side of the fuse.
  5. Sony CDX-GT540UI Fuse Replacement: 步骤 5 中的图像 1,1
    • Rock back and forth gently pulling towards yourself until the fuse is removed.
结论
另外一个人完成了本指南。
Odelkys Marquez
于09/22/14注册
1,091 声望
创作了7篇指南
团队
USF Tampa, Team 10-2, Brown Fall 2014 USF Tampa, Team 10-2, Brown Fall 2014 的会员
USFT-BROWN-F14S10G2
3 名成员
创作了7篇指南
一条评论
I would like to sincerely thank the person or persons that took the time ,energy and effort to put forth this information in an easily accessible way. BASICALLY YOU ARE COOL !!
germanspeedster - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 47
总计 9,260
