跳转到主内容
Sony CDX-GT540UI CD Drive Replacement
你所需要的
  1. Sony CDX-GT540UI CD Drive Replacement, Front Panel: 步骤 1 中的图像 1,1
    • Locate face-plate eject button.
  2. Sony CDX-GT540UI CD Drive Replacement: 步骤 2 中的图像 1,2 Sony CDX-GT540UI CD Drive Replacement: 步骤 2 中的图像 2,2
    • Press the eject button.
    • Remove the face-plate.
  3. Sony CDX-GT540UI CD Drive Replacement: 步骤 3 中的图像 1,3 Sony CDX-GT540UI CD Drive Replacement: 步骤 3 中的图像 2,3 Sony CDX-GT540UI CD Drive Replacement: 步骤 3 中的图像 3,3
    • Remove two 4.9mm Phillips #00screws on the front of the device.
    • Remove two 7.5mm Phillips #00screws on the front of the device.
    • When the screws are removed, the eject lever may fall into the device. Make sure the device is held horizontal and level.
    The screws in red do not seem to need to be removed unless you are trying to replace the eject lever. If you're not trying to replace the lever, it adds an unnecessary complication to putting it back together.
    Dale Pearson - 回复
  4. Sony CDX-GT540UI CD Drive Replacement: 步骤 4 中的图像 1,2 Sony CDX-GT540UI CD Drive Replacement: 步骤 4 中的图像 2,2
    • Rotate device 90 degrees to either side.
    • Use the plastic opening tool to pry open the top and bottom tab respectively.
    • Repeat on opposite side.
  5. Sony CDX-GT540UI CD Drive Replacement: 步骤 5 中的图像 1,1
    • Remove front panel.
  6. Sony CDX-GT540UI CD Drive Replacement, Back Panel: 步骤 6 中的图像 1,1
    • Locate back panel.
  7. Sony CDX-GT540UI CD Drive Replacement: 步骤 7 中的图像 1,3 Sony CDX-GT540UI CD Drive Replacement: 步骤 7 中的图像 2,3 Sony CDX-GT540UI CD Drive Replacement: 步骤 7 中的图像 3,3
    • Remove four 11.5mm Phillips #00 (silver) screws from back panel.
  8. Sony CDX-GT540UI CD Drive Replacement: 步骤 8 中的图像 1,1
    • Remove four 9.5mm Phillips #00 (black) screws from back panel.
    • Remove two 7.5mm Phillips #00 (black) screws from back panel.
  9. Sony CDX-GT540UI CD Drive Replacement: 步骤 9 中的图像 1,1
    • Remove back panel.
    • On the back panel there will be thermal (white) paste. Do not touch.
  10. Sony CDX-GT540UI CD Drive Replacement, CD Drive: 步骤 10 中的图像 1,1
    • Remove one 9.5mm Phillips #00 screw.
    • Rotate device 180 degrees and repeat step.
  11. Sony CDX-GT540UI CD Drive Replacement: 步骤 11 中的图像 1,2 Sony CDX-GT540UI CD Drive Replacement: 步骤 11 中的图像 2,2
    • Using plastic opening tool, detach the tabs. There are two on either side.
    • You will need to apply a decent amount of force to detach.
  12. Sony CDX-GT540UI CD Drive Replacement: 步骤 12 中的图像 1,2 Sony CDX-GT540UI CD Drive Replacement: 步骤 12 中的图像 2,2
    • Remove top panel.
  13. Sony CDX-GT540UI CD Drive Replacement: 步骤 13 中的图像 1,1
    • Pull up CD drive slightly.
  14. Sony CDX-GT540UI CD Drive Replacement: 步骤 14 中的图像 1,1
    • Disconnect motherboard connection.
  15. Sony CDX-GT540UI CD Drive Replacement: 步骤 15 中的图像 1,1
    • Remove CD drive.
结论
2等其他人完成本指南。
Odelkys Marquez
于09/22/14注册
1,091 声望
创作了7篇指南
团队
USF Tampa, Team 10-2, Brown Fall 2014 USF Tampa, Team 10-2, Brown Fall 2014 的会员
USFT-BROWN-F14S10G2
3 名成员
创作了7篇指南
一条评论
This guide is listed as "difficult" yet only requires the use of a screwdriver and some prying tools. It would seem more appropriate to list it as "moderate" at most. I believe the motherboard guide has the same issue.
Also, you say PH#00 in the description of steps, but in the "tools" listing at the beginning of the guide, you said that a PH#0 was needed. These are not the same.
Dale Pearson - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 714
