跳转到主内容
Sony CCD-TR81 Lens Assembly Replacement
你所需要的
  1. Sony CCD-TR81 Lens Assembly Replacement, Disassembling Sony CCD-TR81 Battery: 步骤 1 中的图像 1,1
    • Lift viewfinder to access battery pack.
  2. Sony CCD-TR81 Lens Assembly Replacement: 步骤 2 中的图像 1,2 Sony CCD-TR81 Lens Assembly Replacement: 步骤 2 中的图像 2,2
    • Press the battery release button.
    • While pushing the battery button, slide the battery to the left.
  3. Sony CCD-TR81 Lens Assembly Replacement: 步骤 3 中的图像 1,1
    • Pull the battery pack out of the video camera.
  4. Sony CCD-TR81 Lens Assembly Replacement, Outer Case: 步骤 4 中的图像 1,3 Sony CCD-TR81 Lens Assembly Replacement, Outer Case: 步骤 4 中的图像 2,3 Sony CCD-TR81 Lens Assembly Replacement, Outer Case: 步骤 4 中的图像 3,3
    • Open the cassette cover.
    • Unscrew 14 screws located on the outer casing. Three are located on the top face 2x6.8mm and 1X4.54mm, three on the left face 1x4.54mm,1x5.3mm and seven on the bottom face 5x4.54mm and 2x6.77mm.
  5. Sony CCD-TR81 Lens Assembly Replacement: 步骤 5 中的图像 1,2 Sony CCD-TR81 Lens Assembly Replacement: 步骤 5 中的图像 2,2
    • Remove five screws from the right side, from bottom to top, 3x4.54mm 2x5.70mm.
    • Remove the single 4.5 mm screw from the backside.
  6. Sony CCD-TR81 Lens Assembly Replacement: 步骤 6 中的图像 1,1
    • Pull off the plastic tape cover by lifting it up and out of the camera base.
  7. Sony CCD-TR81 Lens Assembly Replacement: 步骤 7 中的图像 1,1
    • Disconnect the mic assembly by pulling it away from the camera base.
    • Do not pull too hard as the wires are still connected.
  8. Sony CCD-TR81 Lens Assembly Replacement: 步骤 8 中的图像 1,1
    • Pull the bottom part of the case away from the camera.
  9. Sony CCD-TR81 Lens Assembly Replacement: 步骤 9 中的图像 1,1
    • Remove the three 4.5 mm screws from the right face of the video camera.
  10. Sony CCD-TR81 Lens Assembly Replacement: 步骤 10 中的图像 1,1
    • Remove the single 3.6 mm screw at the front of the video camera on the circuit board.
  11. Sony CCD-TR81 Lens Assembly Replacement: 步骤 11 中的图像 1,1
    • Pull the audio/video inputs underneath the microphone assembly. The inputs should still be connected to the circuit board.
  12. Sony CCD-TR81 Lens Assembly Replacement: 步骤 12 中的图像 1,1
    • Remove two remaining 3.6 mm case screws from the front of the camera.
  13. Sony CCD-TR81 Lens Assembly Replacement: 步骤 13 中的图像 1,2 Sony CCD-TR81 Lens Assembly Replacement: 步骤 13 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using metal tweezers, pull out the plastic connector box on the front side.
    • Again use metal tweezers to pull out the connection box on the bottom of the camera. The right side of the case can now be removed by pulling it to the right.
  14. Sony CCD-TR81 Lens Assembly Replacement, Lens Assembly: 步骤 14 中的图像 1,1
    • Remove the three screws from the circuit board.
  15. Sony CCD-TR81 Lens Assembly Replacement: 步骤 15 中的图像 1,2 Sony CCD-TR81 Lens Assembly Replacement: 步骤 15 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using metal tweezers, pull out the plastic connector box located in the center area.
    • Pull up the circuit board.
    • Be careful; it should still be connected to a band wire.
  16. Sony CCD-TR81 Lens Assembly Replacement: 步骤 16 中的图像 1,3 Sony CCD-TR81 Lens Assembly Replacement: 步骤 16 中的图像 2,3 Sony CCD-TR81 Lens Assembly Replacement: 步骤 16 中的图像 3,3
    • Remove all three screws around the lens assembly.
  17. Sony CCD-TR81 Lens Assembly Replacement: 步骤 17 中的图像 1,1
    • Remove three gold screws from the lens assembly.
    • Be careful not to break band wires.
  18. Sony CCD-TR81 Lens Assembly Replacement: 步骤 18 中的图像 1,3 Sony CCD-TR81 Lens Assembly Replacement: 步骤 18 中的图像 2,3 Sony CCD-TR81 Lens Assembly Replacement: 步骤 18 中的图像 3,3
    • Lift the lens assembly from the large circuit board.
    • Remove the two 5.3 mm screws.
    • Remove the single 6.1 mm screw using a Phillips #000 screwdriver.
    • Remove the lens from the lens assembly.
结论
2等其他人完成本指南。
Andrew
于01/23/11注册
58 声望
撰写一个指南
团队
Cal Poly, Team 11-25, Maness Winter 2011 Cal Poly, Team 11-25, Maness Winter 2011 的会员
CPSU-MANESS-W11S11G25
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 15
总计 3,150
