简介
The USB is a very important part of the Sony Bloggie as it is the only way to get your movies from the camera to a computer. This guide will show you how to install a new USB drive in the Sony Bloggie 3D.
你所需要的
Once the back cover is removed, by using the opening tool, remove the following screws using a Phillips #00 screwdriver.
Two 4.0mm Phillips #00 screws
One 8.0mm Phillips #00 screw
One 9.5mm Phillips #00 screw
即将完成!
结论
