跳转到主内容
Sony Bloggie 3D Player Main Button's Circuit Board Replacement
你所需要的
  1. Sony Bloggie 3D Player Main Button's Circuit Board Replacement, Front Cover: 步骤 1 中的图像 1,1
    • Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
  2. Sony Bloggie 3D Player Main Button's Circuit Board Replacement: 步骤 2 中的图像 1,2 Sony Bloggie 3D Player Main Button's Circuit Board Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool to pry the cover open.
    • After the the cover is partly open as shown, remove the cover with your hands.
  3. Sony Bloggie 3D Player Main Button's Circuit Board Replacement, Main Button's Circuit Board: 步骤 3 中的图像 1,2 Sony Bloggie 3D Player Main Button's Circuit Board Replacement, Main Button's Circuit Board: 步骤 3 中的图像 2,2
    • Detach the board from the ZIF connector using a pair of tweezers or by hand.
    • Flip the circuit board over and remove the connector on the backside. Now you can safely remove the circuit board.
结论
Robert Tam
于01/30/13注册
6 声望
创作了2篇指南
团队
Cal Poly, Team 7-12, Maness Winter 2013 Cal Poly, Team 7-12, Maness Winter 2013 的会员
CPSU-MANESS-W13S7G12
5 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 12
总计 377
