跳转到主内容
简介
Whether it's by dust or wear, the Main Button's Circuit Board can malfunction over time. This guide focuses on how to install a new Main Button's Circuit Board to get your device running like new.
  1. Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
    • Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
  2. Skip the upgrade.
    Take $10 off $50 with
    SKIPANDSAVE10
    Save Now
    Skip the upgrade.
    SKIPANDSAVE10
    Save Now
  3. Use a plastic opening tool to pry the cover open. After the the cover is partly open as shown, remove the cover with your hands.
    • Use a plastic opening tool to pry the cover open.
    • After the the cover is partly open as shown, remove the cover with your hands.
  4. Detach the board from the ZIF connector using pair of tweezers or by hand. Flip the circuit board over and remove the connector that is on the backside, now you can safely remove the circuit board.
    • Detach the board from the ZIF connector using pair of tweezers or by hand.
    • Flip the circuit board over and remove the connector that is on the backside, now you can safely remove the circuit board.
结论
Robert Tam
于2013年01月30日注册
6 信誉积分
创作了2篇指南
团队
Cal Poly, Team 7-12, Maness Winter 2013 Cal Poly, Team 7-12, Maness Winter 2013 的会员
CPSU-MANESS-W13S7G12
5 名成员
创作了6篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 284
