跳转到主内容
Sony Bloggie 3D Player Battery Replacement
你所需要的
  1. Sony Bloggie 3D Player Battery Replacement, Front Cover: 步骤 1 中的图像 1,1
    • Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
  2. Sony Bloggie 3D Player Battery Replacement: 步骤 2 中的图像 1,2 Sony Bloggie 3D Player Battery Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool to pry the cover open.
    • After the the cover is partly open as shown, remove the cover with your hands.
  3. Sony Bloggie 3D Player Battery Replacement, Back Cover: 步骤 3 中的图像 1,2 Sony Bloggie 3D Player Battery Replacement, Back Cover: 步骤 3 中的图像 2,2
    • Using your hand, or a pair of tweezers, remove the ZIF connector by gently pulling it out of the dock on the circuit board.
  4. Sony Bloggie 3D Player Battery Replacement: 步骤 4 中的图像 1,2 Sony Bloggie 3D Player Battery Replacement: 步骤 4 中的图像 2,2
    • Use a plastic opening tool to loosen the back cover off the device.
    • Once the back cover is loose, remove it gently by hand.
  5. Sony Bloggie 3D Player Battery Replacement, Battery: 步骤 5 中的图像 1,2 Sony Bloggie 3D Player Battery Replacement, Battery: 步骤 5 中的图像 2,2
    • Remove the battery with your fingers.
结论
Timothy Tran
于01/30/13注册
1 声望
创作了2篇指南
团队
Cal Poly, Team 7-12, Maness Winter 2013 Cal Poly, Team 7-12, Maness Winter 2013 的会员
CPSU-MANESS-W13S7G12
5 名成员
创作了12篇指南
一条评论
You forgot to mention the need to flip the screen up (a screw holds it down) in order to get to a screw holding the back cover. Other than that, thank you for the info.
Rich Brewer - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 26
总计 2,129
