跳转到主内容
Sony Betamovie BMC-220 Power Button Replacement
你所需要的
  1. Sony Betamovie BMC-220 Power Button Replacement, Battery: 步骤 1 中的图像 1,3 Sony Betamovie BMC-220 Power Button Replacement, Battery: 步骤 1 中的图像 2,3 Sony Betamovie BMC-220 Power Button Replacement, Battery: 步骤 1 中的图像 3,3
    • Orient your Betamovie so that the back of the device is sitting flat, and the bottom of the device is facing you.
    • Slide the RELEASE switch up to bring the hand drip down.
  2. Sony Betamovie BMC-220 Power Button Replacement: 步骤 2 中的图像 1,3 Sony Betamovie BMC-220 Power Button Replacement: 步骤 2 中的图像 2,3 Sony Betamovie BMC-220 Power Button Replacement: 步骤 2 中的图像 3,3
    • Turn the BATTERY knob to OPEN, and open the lid.
    • Reminder: When inserting a new battery, make sure the knob is turned to OPEN.
    • Be careful not to point the hand grip down when turning the BATTERY knob. The battery pack may fall out.
  3. Sony Betamovie BMC-220 Power Button Replacement: 步骤 3 中的图像 1,1
    • Remove the battery from the Betamovie.
  4. Sony Betamovie BMC-220 Power Button Replacement, Power Button: 步骤 4 中的图像 1,3 Sony Betamovie BMC-220 Power Button Replacement, Power Button: 步骤 4 中的图像 2,3 Sony Betamovie BMC-220 Power Button Replacement, Power Button: 步骤 4 中的图像 3,3
    • Remove the two screws (2mm x 6mm) on either side of the FILTER switch on the black and white side of the Betamovie using the Phillips #0 screwdriver.
    • Remove the two screws on the bottom of the camera on the side with the black and white face using the same screwdriver.
    • Remove the screws on the bottom of the back of the camera with the same screwdriver.
  5. Sony Betamovie BMC-220 Power Button Replacement: 步骤 5 中的图像 1,2 Sony Betamovie BMC-220 Power Button Replacement: 步骤 5 中的图像 2,2
    • Remove the silver rectangular piece at the top of the Betamovie using your hands.
    • Remove the two screws (2mm x 6mm) under the flat silver piece using the Phillips #1 screwdriver. The silver metal clip comes off once the crews are removed.
  6. Sony Betamovie BMC-220 Power Button Replacement: 步骤 6 中的图像 1,3 Sony Betamovie BMC-220 Power Button Replacement: 步骤 6 中的图像 2,3 Sony Betamovie BMC-220 Power Button Replacement: 步骤 6 中的图像 3,3
    • Remove the black and white cover from the Betamovie.
    • Remove the power button from the black and white face.
结论
Jordan Bates
于09/10/18注册
315 声望
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 523
