跳转到主内容
Sony BDP-s7200 Front Panel Cover Replacement
你所需要的
  1. Sony BDP-s7200 Front Panel Cover Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Remove the disk tray cover from the device.
  2. Sony BDP-s7200 Front Panel Cover Replacement: 步骤 2 中的图像 1,2 Sony BDP-s7200 Front Panel Cover Replacement: 步骤 2 中的图像 2,2
    • Using the Phillips #2 Screwdriver, remove the five 9mm from the bottom of the device.
    • Remove the metal cover.
  3. Sony BDP-s7200 Front Panel Cover Replacement: 步骤 3 中的图像 1,2 Sony BDP-s7200 Front Panel Cover Replacement: 步骤 3 中的图像 2,2
    • Using the Phillips #2 Screwdriver, remove the six 9mm screws from the back of the device.
  4. Sony BDP-s7200 Front Panel Cover Replacement: 步骤 4 中的图像 1,1
    • Pull off the back panel and remove it from the device.
  5. Sony BDP-s7200 Front Panel Cover Replacement, Front Panel Cover: 步骤 5 中的图像 1,3 Sony BDP-s7200 Front Panel Cover Replacement, Front Panel Cover: 步骤 5 中的图像 2,3 Sony BDP-s7200 Front Panel Cover Replacement, Front Panel Cover: 步骤 5 中的图像 3,3
    • Using the plastic opening tool, open one of the tabs on the bottom of the device.
    • While keeping the tab open, insert a opening pick in between the opening tool and tab.
    • Repeat this for the 3 other tabs.
  6. Sony BDP-s7200 Front Panel Cover Replacement: 步骤 6 中的图像 1,2 Sony BDP-s7200 Front Panel Cover Replacement: 步骤 6 中的图像 2,2
    • Place your hands on the two black circles on the bottom of the device.
    • Pull on the black circles to remove the device from its front panel cover.
  7. Sony BDP-s7200 Front Panel Cover Replacement: 步骤 7 中的图像 1,3 Sony BDP-s7200 Front Panel Cover Replacement: 步骤 7 中的图像 2,3 Sony BDP-s7200 Front Panel Cover Replacement: 步骤 7 中的图像 3,3
    • Using the Phillips #2 Screwdriver, remove the seven 9mm screws from the top of the device.
    • Using the same screwdriver, remove the three 9mm screws from the back of the device.
    • Using the same screwdriver, remove the one 9mm screw still connecting the small metal clip to the front of the device.
  8. Sony BDP-s7200 Front Panel Cover Replacement: 步骤 8 中的图像 1,2 Sony BDP-s7200 Front Panel Cover Replacement: 步骤 8 中的图像 2,2
    • Remove the small metal clip on the front of the device.
    • Remove the metal cover on the top of the device.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 208
