跳转到主内容
Sony BDP-S3700 Motherboard Replacement
你所需要的
  1. Sony BDP-S3700 Motherboard Replacement, Front Panel: 步骤 1 中的图像 1,2 Sony BDP-S3700 Motherboard Replacement, Front Panel: 步骤 1 中的图像 2,2
    • Use the PH1 screwdriver to remove the two 9mm screws on the back of the Blu-ray player.
  2. Sony BDP-S3700 Motherboard Replacement: 步骤 2 中的图像 1,2 Sony BDP-S3700 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Remove the back of the device by slowly sliding the rear outer housing backwards.
  3. Sony BDP-S3700 Motherboard Replacement: 步骤 3 中的图像 1,2 Sony BDP-S3700 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Turn the Blu-ray over
    • Pry open the clips under and on the sides
  4. Sony BDP-S3700 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Once all the clips are open, slide the front outer housing out.
  5. Sony BDP-S3700 Motherboard Replacement, Disc Drive: 步骤 5 中的图像 1,3 Sony BDP-S3700 Motherboard Replacement, Disc Drive: 步骤 5 中的图像 2,3 Sony BDP-S3700 Motherboard Replacement, Disc Drive: 步骤 5 中的图像 3,3
    • Flip the Blu-ray back up
    • Remove the three ribbon cables that connect the disc drive to the motherboard.
    • Handle the circuits only on its side.
  6. Sony BDP-S3700 Motherboard Replacement: 步骤 6 中的图像 1,2 Sony BDP-S3700 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Use a PH1 screwdriver to unscrew both of the 7mm screws on the side of the disc reader.
  7. Sony BDP-S3700 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Gently slide the disc drive to the right and lift up to remove the disc drive from the body of the player.
  8. Sony BDP-S3700 Motherboard Replacement, Motherboard: 步骤 8 中的图像 1,2 Sony BDP-S3700 Motherboard Replacement, Motherboard: 步骤 8 中的图像 2,2
    • Gently pull upwards on the ribbon cables to disconnect the motherboard from the Wi-Fi module and port board.
  9. Sony BDP-S3700 Motherboard Replacement: 步骤 9 中的图像 1,3 Sony BDP-S3700 Motherboard Replacement: 步骤 9 中的图像 2,3 Sony BDP-S3700 Motherboard Replacement: 步骤 9 中的图像 3,3
    • Remove the three 7mm screws along the motherboard using a PH1 screwdriver.
  10. Sony BDP-S3700 Motherboard Replacement: 步骤 10 中的图像 1,3 Sony BDP-S3700 Motherboard Replacement: 步骤 10 中的图像 2,3 Sony BDP-S3700 Motherboard Replacement: 步骤 10 中的图像 3,3
    • Remove the 4mm screw above the HDMI port and the 9mm screw Digital Out port.
  11. Sony BDP-S3700 Motherboard Replacement: 步骤 11 中的图像 1,1
    • Carefully lift and pull the motherboard forward to remove.
结论
2等其他人完成本指南。
Luiz Barreto
于02/15/17注册
627 声望
创作了5篇指南
团队
USF Tampa, Team 12-1, Eyestone Spring 2017 USF Tampa, Team 12-1, Eyestone Spring 2017 的会员
USFT-EYESTONE-S17S12G1
4 名成员
创作了5篇指南
2条评论
Thanks for the guide really good! Does anyone know where i can get a sony bdp-s3700 motherboard replacement?
James Durham - 回复
Same problem here.
Julian Robbins -
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 16
总计 1,468
