Carefully lift up the top panel, because there are two blue ribbon cables that must be disconnected before removing the panel, and we do NOT want them to break.
After gently disconnecting the two ribbon cables (you can just pull them out with your hand), take the top off and set it to the side.
Remove the cable ribbon that is attached to the motherboard.
And voila! You have successfully taken out the circuit board.
And here we see the solder that keeps the RC components strapped into the board. In order to get them off and put them back on, you'll need a soldering iron, wick, and solder itself.
If you don't know how to solder properly, there are plenty of helpful guides online, such as this one. Make sure to remove the solder all the way before removing the RC jacks, otherwise you could hurt the board.
Now you just have to take off the RC components, place the news ones in, and solder them into the board (again using a soldering guide if you need to).
Good work! Now celebrate by listening to your favorite movie!
