跳转到主内容
Sony BDP-BX620 Motherboard Replacement
你所需要的
  1. Sony BDP-BX620 Motherboard Replacement, Outer Cover: 步骤 1 中的图像 1,2 Sony BDP-BX620 Motherboard Replacement, Outer Cover: 步骤 1 中的图像 2,2
    • Power on the device, eject the disk tray, and power off the device.
    • Turn the device over.
    • Lightly apply downward pressure on the black covering on the disk tray until it comes off.
    • Caution, applying too much pressure can break the black covering.
  2. Sony BDP-BX620 Motherboard Replacement: 步骤 2 中的图像 1,2 Sony BDP-BX620 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Turn the device around.
    • Using a Phillips screw driver, remove the screws on both ends of the device circled red in the image.
    • Slide the side covers on either side towards the back of the device.
    • There is a back cover on either side of the device.
  3. Sony BDP-BX620 Motherboard Replacement: 步骤 3 中的图像 1,3 Sony BDP-BX620 Motherboard Replacement: 步骤 3 中的图像 2,3 Sony BDP-BX620 Motherboard Replacement: 步骤 3 中的图像 3,3
    • This step might require someone to help unclasping the plastic clips.
    • Turn the device so that the bottom is facing up.
    • In the bottom, unclip the three plastic clips circled in red.
    • On either side, unclip the plastic clip circled in red
    • Slide the black covering forwards to remove.
    • All five clips have to be unclasped for the covering to be removed.
    • Careful not to break the plastic clips when putting it back on.
  4. Sony BDP-BX620 Motherboard Replacement, Power Module: 步骤 4 中的图像 1,1
    • Gently pull on up on the power cord to unlatch it from the metal body of the device.
  5. Sony BDP-BX620 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove the cable connecting the Power Port to the Motherboard by pulling up.
    • It may be difficult to remove. Pull from the plastic part and not the wiring to prevent the wiring from breaking.
  6. Sony BDP-BX620 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Remove both screws using the Phillips screw driver.
  7. Sony BDP-BX620 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Lift the Power Module up from the side. See picture.
    • Pull up and away to remove the Power Module
  8. Sony BDP-BX620 Motherboard Replacement, Motherboard: 步骤 8 中的图像 1,3 Sony BDP-BX620 Motherboard Replacement, Motherboard: 步骤 8 中的图像 2,3 Sony BDP-BX620 Motherboard Replacement, Motherboard: 步骤 8 中的图像 3,3
    • Remove the white ribbon cables connecting the motherboard to the display. The thick white ribbon cable in the middle needs the release button to be pressed down to allow it to come loose.
    • Remove the white ribbon cables connecting the motherboard to the disk drive. Be careful to not use too much force to not tear the cables.
  9. Sony BDP-BX620 Motherboard Replacement: 步骤 9 中的图像 1,2 Sony BDP-BX620 Motherboard Replacement: 步骤 9 中的图像 2,2
    • Once the ribbon cables are removed, remove the three screws holding the motherboard to the base of the player.
    • Finally remove the screw from the back of the player holding the motherboard in place.
结论
另外一个人完成了本指南。
Benjamin
于09/12/16注册
92 声望
撰写一个指南
团队
USF Tampa, Team 1-6, Lacy Fall 2016 USF Tampa, Team 1-6, Lacy Fall 2016 的会员
USFT-LACY-F16S1G6
4 名成员
创作了6篇指南
一条评论
OK, but here’s the next step. I’m trying to get to the CPU now under that aluminum fin cooling plate. However, I can’t for the life of me find how to unhook those 4 hooks holding it down on the CPU. Any suggestions? Preferably without having to buy equipment, but if I must, what should I get?
danthemanyankeefan - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 278
