跳转到主内容
Sony BDP-BX520 Disc Reader Replacement
你所需要的
  1. Sony BDP-BX520 Disc Reader Replacement, Disc Tray Cover: 步骤 1 中的图像 1,1
    • Plug in the Blu-Ray player, then press the power button, making sure the Blu-Ray player is powered on.
    • Press the eject button on either the top of the Blu-Ray player or on the remote to open the disc tray.
  2. Sony BDP-BX520 Disc Reader Replacement: 步骤 2 中的图像 1,1
    • Grab the sides of the disc tray cover and carefully pull each side upwards, starting with the left side. This will unhook the cover from the tray.
  3. Sony BDP-BX520 Disc Reader Replacement: 步骤 3 中的图像 1,1
    • Close the disc tray, then power off and unplug the Blu-Ray player.
  4. Sony BDP-BX520 Disc Reader Replacement, Top Case: 步骤 4 中的图像 1,1
    • Locate the three 8 mm screws on the back of the Blu-Ray player.
    • Using the Phillips #2 screwdriver, unscrew each of the screws and set them aside.
  5. Sony BDP-BX520 Disc Reader Replacement: 步骤 5 中的图像 1,2 Sony BDP-BX520 Disc Reader Replacement: 步骤 5 中的图像 2,2
    • Gently pull the top case back to remove it from the Blu-Ray player.
  6. Sony BDP-BX520 Disc Reader Replacement, Front Panel: 步骤 6 中的图像 1,1
    • Insert the nylon or metal spudger under the clip on the side near the front of the device. Lift the clip so it is free from the device.
    • Lifting these clips may require you to hold one clip open while you move on to the next clip.
  7. Sony BDP-BX520 Disc Reader Replacement: 步骤 7 中的图像 1,1
    • Flip device over so the bottom faces you.
    • Insert the nylon or metal spudger and lift the two clips on the bottom of the device.
  8. Sony BDP-BX520 Disc Reader Replacement: 步骤 8 中的图像 1,1
    • Lift the clip on the opposite side of the device with the nylon or metal spudger.
  9. Sony BDP-BX520 Disc Reader Replacement: 步骤 9 中的图像 1,2 Sony BDP-BX520 Disc Reader Replacement: 步骤 9 中的图像 2,2
    • Grasp the front case firmly and lift from the rest of the device.
    • Lifting may require some force.
  10. Sony BDP-BX520 Disc Reader Replacement, Disc Reader: 步骤 10 中的图像 1,1
    • Do not touch the circuit boards or the internal parts of the device while it is powered on. This could short out the circuits and possibly cause you harm.
    • Plug in the device and power it on by pushing the right button on the front of the device. The light should turn on.
  11. Sony BDP-BX520 Disc Reader Replacement: 步骤 11 中的图像 1,1
    • Eject the disc tray by pushing the left button on the front of the device.
    • Unplug the device once the disc tray is open.
  12. Sony BDP-BX520 Disc Reader Replacement: 步骤 12 中的图像 1,1
    • Insert the nylon or metal spudger under the clip and lift it up. There are 4 clips that need to be lifted, two on each side
  13. Sony BDP-BX520 Disc Reader Replacement: 步骤 13 中的图像 1,2 Sony BDP-BX520 Disc Reader Replacement: 步骤 13 中的图像 2,2
    • Once the clips are free, lift the top cover of the disc tray up.
    • This should take minimal force.
  14. Sony BDP-BX520 Disc Reader Replacement: 步骤 14 中的图像 1,1
    • Unscrew the two silver 8mm Phillips 1 screws from the disc reader.
  15. Sony BDP-BX520 Disc Reader Replacement: 步骤 15 中的图像 1,3 Sony BDP-BX520 Disc Reader Replacement: 步骤 15 中的图像 2,3 Sony BDP-BX520 Disc Reader Replacement: 步骤 15 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use the tweezers to lift both sides of the black clip holding the white 14 pin ribbon in place.
    • Once free the white 24 pin ribbon should slip right out.
  16. Sony BDP-BX520 Disc Reader Replacement: 步骤 16 中的图像 1,2 Sony BDP-BX520 Disc Reader Replacement: 步骤 16 中的图像 2,2
    • Carefully lift up the disc reader. It is still attached by a cable underneath!
  17. Sony BDP-BX520 Disc Reader Replacement: 步骤 17 中的图像 1,2 Sony BDP-BX520 Disc Reader Replacement: 步骤 17 中的图像 2,2
    • Gently pull out the white 13 pin cable from the disc reader.
结论
另外一个人完成了本指南。
Kyle Smit
于01/31/15注册
243 声望
创作了2篇指南
团队
Cal Poly, Team 8-41, Amido Winter 2015 Cal Poly, Team 8-41, Amido Winter 2015 的会员
CPSU-AMIDO-W15S8G41
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 1,276
