跳转到主内容
Sony BDP-BX510 Disk Tray Replacement
你所需要的
  1. Sony BDP-BX510 Disk Tray Replacement, Outer Cover: 步骤 1 中的图像 1,1
    • Plug in the device to turn it on, then press the eject ( ⏏ ) button to open the tray.
  2. Sony BDP-BX510 Disk Tray Replacement: 步骤 2 中的图像 1,2 Sony BDP-BX510 Disk Tray Replacement: 步骤 2 中的图像 2,2
    • To remove the tray cover, hold both sides of the tray cover and gently apply a downward pressure.
    • Apply slightly more pressure to the left side until it unhooks then unhook the right side.
    • Close the disk tray by pressing the eject button again, then power off the device and unplug it.
    • Do not use too much force to remove the tray cover as you may break it.
  3. Sony BDP-BX510 Disk Tray Replacement: 步骤 3 中的图像 1,2 Sony BDP-BX510 Disk Tray Replacement: 步骤 3 中的图像 2,2
    • Turn to the back of the device.
    • Remove the two 7mm Phillips #2 screws.
    • Slide the two plastic covers on both sides of the device towards the back of the device to remove them.
  4. Sony BDP-BX510 Disk Tray Replacement: 步骤 4 中的图像 1,3 Sony BDP-BX510 Disk Tray Replacement: 步骤 4 中的图像 2,3 Sony BDP-BX510 Disk Tray Replacement: 步骤 4 中的图像 3,3
    • Turn the device so you can see the bottom.
    • Unclip the three black plastic clips on the bottom of the device.
    • Unclip one clip on each side of the device.
  5. Sony BDP-BX510 Disk Tray Replacement: 步骤 5 中的图像 1,1
    • Slide the cover forward to remove.
  6. Sony BDP-BX510 Disk Tray Replacement, Disk Tray: 步骤 6 中的图像 1,2 Sony BDP-BX510 Disk Tray Replacement, Disk Tray: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Pull the medium-sized 9 pin ribbon cable and the small 5 pin ribbon cable out of their connector in the motherboard.
    • Using tweezers, lift the black tab on the connector of the large 45 pin connector on the motherboard.
    • Pull the large 45 pin ribbon cable out of the connector in the motherboard.
    • Be very careful. The goal is to slightly lift the pin connector, not to completely detach it. Do not forcibly pull.
  7. Sony BDP-BX510 Disk Tray Replacement: 步骤 7 中的图像 1,1
    • Remove the 5mm Phillips #2 screw holding the metal brace above the disk tray.
    • Remove the two 5mm Phillips #2 screws that hold the disk tray to the metal case on the bottom.
  8. Sony BDP-BX510 Disk Tray Replacement: 步骤 8 中的图像 1,3 Sony BDP-BX510 Disk Tray Replacement: 步骤 8 中的图像 2,3 Sony BDP-BX510 Disk Tray Replacement: 步骤 8 中的图像 3,3
    • Turn the device over to the backside.
    • Use tweezers or hands to take off the metal clasp for the metal brace near the center on the bottom of the device.
  9. Sony BDP-BX510 Disk Tray Replacement: 步骤 9 中的图像 1,1
    • Remove the metal brace then remove the disk tray.
结论
Tae (Tim) Im
于01/14/20注册
279 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 304
