跳转到主内容
Sony BDP BX350 Motherboard Replacement
你所需要的
  1. Sony BDP BX350 Motherboard Replacement, Disc Assembly: 步骤 1 中的图像 1,1
    • Remove the three 10mm Philips head screws on the back of the player.
  2. Sony BDP BX350 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Using an opening tool lift up the tabs located on the bottom of the plastic front cover.
  3. Sony BDP BX350 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Lift the tabs located on each side of the device to free the front cover. Begin to separate the front and metal back covers.
  4. Sony BDP BX350 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Completely separate the front cover and the metal back cover from the grey casing.
    • The inner components should all be completely exposed after opening.
  5. Sony BDP BX350 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Unscrew the two 8mm Philips head screws securing the disc assembly to the main casing.
  6. Sony BDP BX350 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Pull the disc assembly out from under the metal tabs on the main casing.
  7. Sony BDP BX350 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Remove disc assembly.
  8. Sony BDP BX350 Motherboard Replacement, Motherboard: 步骤 8 中的图像 1,2 Sony BDP BX350 Motherboard Replacement, Motherboard: 步骤 8 中的图像 2,2
    • Do not bend or tear the ribbon cable.
    • Remove all five ribbon cables from the motherboard.
  9. Sony BDP BX350 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Unscrew 3mm Philips head HDMI screw from metal casing.
  10. Sony BDP BX350 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Unscrew the three 5mm Philips head screws from motherboard.
    • Separate the motherboard from the metal casing by pulling directly up. Use an opening tool if necessary.
结论
Kristen Vezina
于03/06/17注册
413 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 19
总计 610
