跳转到主内容
Sony Alpha a7s II Tripod Mount Replacement
你所需要的
  1. Sony Alpha a7s II Tripod Mount Replacement, Tripod Mount: 步骤 1 中的图像 1,2 Sony Alpha a7s II Tripod Mount Replacement, Tripod Mount: 步骤 1 中的图像 2,2
    • Orient your camera so that you are looking at the bottom portion.
    • Using a JIS #00 screwdriver, remove the 7 screws that are securing the metal plate to the bottom of your camera.
    • You do not need to remove that recessed screw that is not connected to the bottom metal plate.
  2. Sony Alpha a7s II Tripod Mount Replacement: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Remove metal plate. Sometimes this plate can become stuck and hard to remove. Use tweezers to separate the plate from the bottom of the camera.
  3. Sony Alpha a7s II Tripod Mount Replacement: 步骤 3 中的图像 1,1
    • Flip the plate to the opposite side exposing the aspect that was just inside of the camera.
    • Use the JIS #00 screwdriver to unscrew the the 3 screws surrounding the tripod mount.
  4. Sony Alpha a7s II Tripod Mount Replacement: 步骤 4 中的图像 1,1
    • Remove the tripod mount from the metal plate.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 55
总计 2,632
