跳转到主内容
Sony Alpha a7s II Diopter Replacement
你所需要的
  1. Sony Alpha a7s II Diopter Replacement, Diopter: 步骤 1 中的图像 1,1
    • Orient your camera so that you are looking at the posterior portion.
  2. Sony Alpha a7s II Diopter Replacement: 步骤 2 中的图像 1,1
    • Place each of your thumbs on the interior portions of the eyepiece cup, pressing down and pushing up.
  3. Sony Alpha a7s II Diopter Replacement: 步骤 3 中的图像 1,1
    • Slide the eyepiece off by carefully pulling it upward.
    • Be careful not to come into contact with the viewfinder lens as the lens can be easily scratched.
  4. Sony Alpha a7s II Diopter Replacement: 步骤 4 中的图像 1,1
    • Remove the screw from the middle of the diopter with the JIS #00 screwdriver.
  5. Sony Alpha a7s II Diopter Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Remove the diopter with your hands. If the diopter is at all stuck you can use the pointed tweezers to help aid in the removal process.
    • Be careful not to let fingers or tweezers come into contact with the viewfinder lens as the lens can be easily scratched.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 38
总计 2,085
