跳转到主内容
Sony Alpha a7S II Viewfinder Plate Replacement
你所需要的
  1. Sony Alpha a7S II Viewfinder Plate Replacement, Diopter: 步骤 1 中的图像 1,1
    • Orient your camera so that you are looking at the posterior portion.
  2. Sony Alpha a7S II Viewfinder Plate Replacement: 步骤 2 中的图像 1,1
    • Place each of your thumbs on the interior portions of the eyepiece cup, pressing down and pushing up.
  3. Sony Alpha a7S II Viewfinder Plate Replacement: 步骤 3 中的图像 1,1
    • Slide the eyepiece off by carefully pulling it upward.
    • Be careful not to come into contact with the viewfinder lens as the lens can be easily scratched.
  4. Sony Alpha a7S II Viewfinder Plate Replacement: 步骤 4 中的图像 1,1
    • Remove the screw from the middle of the diopter with the JIS #00 screwdriver.
  5. Sony Alpha a7S II Viewfinder Plate Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Remove the diopter with your hands. If the diopter is at all stuck you can use the pointed tweezers to help aid in the removal process.
    • Be careful not to let fingers or tweezers come into contact with the viewfinder lens as the lens can be easily scratched.
  6. Sony Alpha a7S II Viewfinder Plate Replacement, Viewfinder Plate: 步骤 6 中的图像 1,1
    • Remove the 4 screws on the viewfinder plate with a JIS #00 screwdriver.
  7. Sony Alpha a7S II Viewfinder Plate Replacement: 步骤 7 中的图像 1,2 Sony Alpha a7S II Viewfinder Plate Replacement: 步骤 7 中的图像 2,2
    • Carefully remove the plastic viewfinder plate from the camera.
结论
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 22
过去 30 天: 86
总计 4,541
